◆ CreateFromSoftware() [1/3]
static MotionController * CreateFromSoftware ( )
static
CreateFromSoftware returns a pointer to the MotionController object it represents, and starts RMP.rta if it is not already running
(MotionController*) A static pointer to the controller specified.
Initialize the RMP EtherCAT motion controller.
// -- C++ -- //
Definition rsi.h:794
// -- C# -- //
The controller is initialized when this function is called. During the initialization process, if RMP.rta is not running, it will be started. The EtherCAT network is NOT started.
Important usage instructions for all RapidCode creation methods: All creation methods, such as and Create(), AxisGet(), NetworkNodeGet(), etc. Each return valid pointers to RapidCode objects. These pointers are never null, even when there is an error during object creation.
Error Checking After Creation
Handling Errors
Helper Functions
Notes on creation methods with the C# API (vs. C++)
Object Cleanup Any and all objects created by RapidCode creation methods will be cleaned up by calling MotionController::Delete(). This should be done with your application is finished using RapidCode objects.
ErrorLogCountGet , ErrorLogGet , Delete , HelperFunctions.CheckErrors
NetworkStart, NetworkStateGet, Delete
HelperFunctions.cs, Template.cs, TouchProbe.cs, and VelocitySetByAnalogInputValue.cs.
