11.0.3
HardwarePosLimitTriggerStateGet()
bool HardwarePosLimitTriggerStateGet
HardwarePosLimitTriggerStateGet returns if the Hardware Positive Limit Trigger is Active High or Active Low.
(int32_t) 1 = triggers on active high signal, 0 = triggers on active low signal.
Axis: Configuration
bool
ACTIVE_HIGH =
true
bool
ACTIVE_LOW =
false
double
HW_POS_DURATION_TIME = 0.01;
// Positive limit duration (in seconds)
double
HW_NEG_DURATION_TIME = 0.01;
// Negative limit duration (in seconds)
// set pos & neg limits
axis.
HardwarePosLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_HIGH);
axis.
HardwarePosLimitDurationSet
(HW_POS_DURATION_TIME);
axis.
HardwareNegLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_LOW);
axis.
HardwareNegLimitDurationSet
(HW_NEG_DURATION_TIME);
// get pos & neg limits
hPosLimAct = axis.
HardwarePosLimitActionGet
bool
hPosLimTrigState = axis.
double
hPosLimDur = axis.
HardwarePosLimitDurationGet
hNegLimAct = axis.
HardwareNegLimitActionGet
bool
hNegLimTrigState = axis.
double
hNegLimDur = axis.
HardwareNegLimitDurationGet
Go to axis screen->Limits & Actions. In the image below, HardwarePosLimitTriggerStateGet returns the trigger state shown in the Positive (+) Hardware box. It currently triggers on a HIGH because the "High" checkbox is checked.
HardwareLimits.cpp
, and
axis-configuration.cpp
1.15.0
