58using RSI.RapidCode.dotNET;
72 const int TOUCH_PROBE_OUTPUT_INDEX = 3;
73 const int TOUCH_PROBE_STATUS_INDEX = 6;
74 const int TOUCH_PROBE_VALUE_INDEX = 7;
79 const ulong TOUCH_PROBE_ON_EACH_Z_PHASE_COMMAND = 0x17;
100 const int TOUCH_PROBE_OUTPUT_INDEX = 3;
101 const int TOUCH_PROBE_STATUS_INDEX = 6;
103 const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX = 0x60BD;
104 const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX = 0x0;
105 const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE = 0x4;
110 const ulong TOUCH_PROBE_2_ON_FIRST_FALLING_EXT2_COMMAND = 0x2100;
113 controller.
NetworkOutputValueSet(TOUCH_PROBE_OUTPUT_INDEX, TOUCH_PROBE_2_ON_FIRST_FALLING_EXT2_COMMAND);
120 int fallingEdgeExt2 = axis.
NetworkNode.
ServiceChannelRead(TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX, TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX, TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE);
125 static void Main(
string[] args)
134 CaptureEachIndexPulseDuringMotion(controller);
136 CapturePositionOnFallingEdgeOfSI6(controller, axis);
NetworkNode * NetworkNode
Sets a PDO output directly.
int32_t ServiceChannelRead(int32_t index, int32_t subIndex, int32_t byteCount)
Read a number from the SDO.
