Memory.cpp
#include "SampleApps.h"
int Memory::Run()
/* CONSTANTS */
USE_HARDWARE = false;
/* SAMPLE APP BODY*/
Axis* axis;
uint64_t addr;
// Initialize MotionController class. (PCI board)
if (USE_HARDWARE)
// initialize Axis (0)
axis = controller->AxisGet(AXIS_NUMBER);
// get a controller host address for axis memory
addr = axis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeACTUAL_POSITION);
printf("Axis Host address is 0x%llx Firmware Address is 0x%x\n", addr, controller->FirmwareAddressGet(addr));
printf("Value is %lf\n", controller->MemoryDoubleGet(addr)); // ACTUAL_POSITION is a 64-bit double
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
Definition rsi.h:5862
uint32_t FirmwareAddressGet(uint64_t hostAddress)
Convert a host controller address to a firmware address.
double MemoryDoubleGet(uint64_t address)
Read a 64-bit double value from controller memory.
Definition rsi.h:800
Definition rsi.h:111
