ControllerInterrupts.cpp
24#include "rsi.h" // Import our RapidCode Library.
25#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
26using namespace RSI::RapidCode; // Import the RapidCode namespace
27
28void controllerInterruptsMain()
29{
31 const int TIMEOUT = (5000); //ms
32
33 RSIEventType interruptType;
34
35 // Initialize Controller, enable interrupts
38
39 controller->InterruptEnableSet(true);
40 try
41 {
42 SampleAppsHelper::StartTheNetwork(controller); // [Helper Function] Initialize the network.
43
44 while (controller->OS->KeyGet((int32_t)RSIWait::RSIWaitPOLL) < 0)
45 {
46 // add code here to generate interrupts (move axes, etc.)
47
48 // wait for an interrupt
49 interruptType = controller->InterruptWait(TIMEOUT);
50
51 if (interruptType != RSIEventType::RSIEventTypeTIMEOUT)
52 {
53 printf("IRQ %ld\n", interruptType);
54 printf("%s\n", controller->InterruptNameGet());
55 printf("InterruptSourceNumber = %ld\n", controller->InterruptSourceNumberGet());
56 printf("InterruptSampleTimer = %ld\n", controller->InterruptSampleTimeGet());
57 printf("\n");
58 }
59 else
60 {
61 printf("Timeout waiting for interrupts...\n");
62 }
63 }
64 }
65 catch (RsiError const& err)
66 {
67 printf("\n%s\n", err.text);
68 }
69 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
70 system("pause"); // Allow time to read Console.
72}
73
Definition rsi.h:795
RapidCodeOS * OS
Definition rsi.h:3697
int32_t InterruptSampleTimeGet()
const char *const InterruptNameGet()
Definition rsi.h:106
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:920
