This namespace includes the source code of all our SampleAppsCPP helper functions.
Helper functions were created to reduce code. Please note that if you would like to use this classes on your personal project you will have to replicate this class.
- Precondition
- This sample code presumes that the user has set the tuning paramters(PID, PIV, etc.) prior to running this program so that the motor can rotate in a stable manner.
- Warning
- This is a sample program to assist in the integration of the RMP motion controller with your application. It may not contain all of the logic and safety features that your application requires.
📜 Sample Apps Config
This struct provides static methods and constants for user configuration in RMP applications. Everything in this struct is expected to be modifed by the user.
throw std::runtime_error("You must implement the ConfigureHardwareAxes function (found in /include/SampleAppsHelper.h) to use hardware.");
📜 Get Creation Parameters
#if _WIN32
return params;
#elif __linux__
return params;
#endif
📜 Check Errors
Check the RSIError log for any logged errors. Read and print all the errors. Ignore warnings.
bool hasErrors = false;
std::string errorStrings("");
errorStrings += err->
what();
errorStrings += "\n";
hasErrors = true;
if (hasErrors)
throw std::runtime_error(errorStrings.c_str());
📜 Start The Network
Start the network and print any errors encountered.
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
if (controller->
📜 Shutdown The Network
Shutdown the network and print any errors encountered.
if (controller->
NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
return;
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
📜 Configure Phantom Axis
10.0;
📜 Setup Controller
if (controller->
std::cout << "The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n";
std::cout << "If you intended to run with hardware, then follow the steps in README.md and /include/SampleAppsHelper.h\n";
📜 Setup Controller For Hardware
📜 Clear Controller Counts
Clears count settings for axes, motion, and user limits on the controller.
📜 Setup Controller For Phantoms
for (auto axisNum : axisNums)
📜 Print Header
std::cout << "----------------------------------------------------------------------------------------------------\n";
std::cout << "Running " << sampleAppName << " Sample App\n";
std::cout << "----------------------------------------------------------------------------------------------------\n" << std::endl;
📜 Print Footer
static void PrintFooter(std::string sampleAppName,
int exitCode)
std::cout << "\n----------------------------------------------------------------------------------------------------\n";
if (exitCode == 0)
std::cout << sampleAppName << " Sample App Completed Successfully\n";
std::cout << sampleAppName << " Sample App Failed with Exit Code: " << exitCode << "\n";
