◆ IOGet()
IO * IOGet ( int32_t nodeNumber)
nodeNumberThe reference number of the node the IO is on. The first I/O node is the 0th Node. Non-I/O Nodes are not considered for this numbering schema.
(IO*) A pointer to the IO specified.
The RMP assigns a logical number to each network node that it encounters during initialization. This number starts with 0 and will be incremented for each node discovered...
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
Deprecated
Use MotionController::NetworkNodeGet instead.
SingleAxisSyncOutputs.cpp, Template.cpp, UserLimitDigitalInputAction.cpp, and VelocitySetByAnalogInputValue.cs.
