10.6.0
CreateDigitalInput()
[4/5]
static
IOPoint
* CreateDigitalInput
MotionController
controller
uint64_t
memoryAddress
int32_t
bitNumber
static
controller
Your motion controller object
memoryAddress
the memory address you want to target
bitNumber
The bit number relative to the memory address
IOPoint
IO: Input & Output
const
int
NODE_INDEX = 0;
// The EtherCAT Node we will be communicating with
const
int
OUTPUT_INDEX = 0;
IOPoint
output0 =
IOPoint
CreateDigitalOutput
(controller.
NetworkNodeGet
(NODE_INDEX), OUTPUT_INDEX);
// Automatically gets the memory index of a specified node and input index
output0.
Set
false
controller.
SampleWait
(1);
Assert.That(output0.
Get
(), Is.False,
"The getter function should return a value equal to false"
IOPoint
1.10.0
