◆ NetworkIndexSet()
void NetworkIndexSet ( RSINetworkIndexType indexType,
uint32_t newIndex )
Redirects where the axis reads/writes a specific signal type in the global PDO array. Use this to:
  • Route motion commands to non-standard PDO entries (e.g., send velocity to a custom torque PDO)
  • Configure axes with proprietary drives that don't follow DS402 conventions
  • Swap feedback sources (e.g., use auxiliary encoder as primary position feedback)
  • Send firmware-calculated outputs (position, velocity, torque) to any network PDO
The firmware writes calculated motion values to the configured PDO index each cycle, allowing flexible routing of control signals without modifying ENI files or drive configurations.
indexTypeThe axis signal type to remap (position demand, velocity demand, target torque, etc.)
newIndexThe target PDO Network index to read from or write to.
// Example 1: Swap primary and auxiliary encoder feedback
uint32_t primaryIndex = axis->NetworkIndexGet(RSINetworkIndexType::NetworkIndexTypePOSITION_ACTUAL_INDEX);
uint32_t auxIndex = axis->NetworkIndexGet(RSINetworkIndexType::NetworkIndexTypeAUX_POSITION_FEEDBACK_INDEX);
// Example 2: Route velocity demand to a custom torque feedforward PDO (index 73)
// Firmware will write velocity values to PDO[73] instead of the default velocity demand PDO
// Example 3: Send calculated torque output to a 32-bit PDO for extended range
// Default torque PDO is 16-bit, but PDO index 42 is configured as 32-bit
@ NetworkIndexTypeVELOCITY_DEMAND_INDEX
Target Velocity (DS402 0x60FF) - 32-bit velocity setpoint in counts/sample.
Definition rsienums.h:1493
@ NetworkIndexTypeAUX_POSITION_FEEDBACK_INDEX
Auxiliary Encoder - 32-bit secondary encoder feedback (vendor-specific).
Definition rsienums.h:1488
@ NetworkIndexTypeTARGET_TORQUE_INDEX
Target Torque (DS402 0x6071) - 16-bit torque/current setpoint (‰ of rated torque).
Definition rsienums.h:1494
@ NetworkIndexTypePOSITION_ACTUAL_INDEX
Position Actual Value (DS402 0x6064) - 32-bit encoder feedback in counts.
Definition rsienums.h:1482
NetworkIndexGet, MotionController::NetworkOutputSentValueGet, MotionController::NetworkInputValueGet, ::RSINetworkIndexType
