10.6.0
HardwarePosLimitTriggerStateSet()
void HardwarePosLimitTriggerStateSet
bool
state
HardwarePosLimitTriggerStateSet sets the Hardware Positive Limit to Active High or Active Low.
state
1 = triggers on active high signal, 0 = triggers on active low signal.
Axis: Configuration
const
bool
ACTIVE_HIGH =
true
// Constant for active high.
const
bool
ACTIVE_LOW =
false
// Constant for active low.
const
double
HW_POS_DURATION_TIME = 0.01;
const
double
HW_NEG_DURATION_TIME = 0.01;
axis.
HardwarePosLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_HIGH);
axis.
HardwarePosLimitDurationSet
(HW_POS_DURATION_TIME);
// GET
var hPosLimAct = axis.
HardwarePosLimitActionGet
var hPosLimTrigState = axis.
var hPosLimDur = axis.
HardwarePosLimitDurationGet
axis.
HardwareNegLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_LOW);
axis.
HardwareNegLimitDurationSet
(HW_NEG_DURATION_TIME);
// GET
var hNegLimAct = axis.
HardwareNegLimitActionGet
var hNegLimTrigState = axis.
var hNegLimDur = axis.
HardwareNegLimitDurationGet
Go to axis screen->Limits & Actions. In the image below, HardwarePosLimitTriggerStateSet sets the trigger state shown in the Positive (+) Hardware box. It currently triggers on a HIGH because the "High" checkbox is checked.
AxisConfig.cs
AxisConfiguration.cpp
, and
HardwareLimits.cpp
1.10.0
