using RSI.RapidCode.dotNET;
#if DOXYGEN
#endif
class TouchProbe
      const int TOUCH_PROBE_OUTPUT_INDEX = 3;
      const int TOUCH_PROBE_STATUS_INDEX = 6;
      const int TOUCH_PROBE_VALUE_INDEX  = 7;
      const ulong TOUCH_PROBE_ON_EACH_Z_PHASE_COMMAND = 0x17;
      const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX     = 0x60BD;
      const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX = 0x0;
      const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE      = 0x4;
      const ulong TOUCH_PROBE_2_ON_FIRST_FALLING_EXT2_COMMAND = 0x2100;
      int fallingEdgeExt2 = axis.
NetworkNode.
ServiceChannelRead(TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX, TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX, TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE);
    static void Main(string[] args)
      CaptureEachIndexPulseDuringMotion(controller);
      CapturePositionOnFallingEdgeOfSI6(controller, axis);
NetworkNode * NetworkNode
Sets a PDO output directly.
int32_t ServiceChannelRead(int32_t index, int32_t subIndex, int32_t byteCount)
