RTTasksHelpers.h
Attention
See the following Concept pages for a detailed explanation of this sample: Real-Time Tasks.
#ifndef RT_TASKS_HELPERS
#define RT_TASKS_HELPERS
#include "rttask.h"
#include <iostream>
#include <memory>
using namespace RSI::RapidCode; // Import our RapidCode namespace
using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
namespace RTTaskHelper
// Get the creation parameters for the task manager
#if defined(WIN32) && defined(NDEBUG)
// If we are on Windows and not Debug, then we need to create an INtime task manager
RTTaskManagerCreationParameters GetTaskManagerCreationParameters()
std::snprintf(
parameters.RTTaskDirectory,
RTTaskManagerCreationParameters::DirectoryLengthMaximum,
RMP_DEFAULT_PATH // The RMP install directory
parameters.Platform = PlatformType::INtime;
std::snprintf(
parameters.NodeName,
RTTaskManagerCreationParameters::NameLengthMaximum,
"NodeA"
return parameters;
#else
// Otherwise, we are on Linux or Debug, so we can create a native task manager
std::snprintf(
// For Linux real-time set this to a isolated core
// parameters.CpuCore = -1;
return parameters;
#endif // defined(WIN32) && defined(NDEBUG)
// This calls a task to initialize the global variables and get pointers to RapidCode objects
// in the RTTaskFunctions library. It needs to be called before any task
// that uses RapidCode objects.
void InitializeRTTaskObjects(RTTaskManager& manager)
std::cout << "Running initialization task..." << std::endl;
RTTaskCreationParameters initParams("Initialize");
initParams.Repeats = RTTaskCreationParameters::RepeatNone;
RTTask task = manager.TaskSubmit(initParams);
constexpr int timeoutMs = 5000;
task.ExecutionCountAbsoluteWait(1, timeoutMs); // Wait for the task to execute once.
#endif // RT_TASKS_HELPERS
Definition rttask.h:435
RTTask TaskSubmit(const RTTaskCreationParameters &parameters)
Submit a new task to the manager using creation parameters.
Interface for managing real-time tasks firmware. See Real-Time Tasks for more information.
Definition rttask.h:554
The RealTimeTasks namespace.
Definition rttask.h:126
int32_t Repeats
Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
Definition rttask.h:170
Definition rttask.h:320
PlatformType Platform
Platform on which the manager firmware will run.
Definition rttask.h:342
char NodeName[NameLengthMaximum]
[INtime] Name of the node on which the manager will run. By default, this is set to (and verified as)...
Definition rttask.h:346
char RTTaskDirectory[DirectoryLengthMaximum]
Path to the directory containing the real-time task libraries.
Definition rttask.h:339
