◆ Get() [1/2]
MotionController * Get ( const char *const nodeName)
static
Description: Attach to the RMP firmware running on the given INtime node. This will NOT
start the RMP firmware if it is not already running on that node.
On Windows the INtime node name – not the controller index, which is process-local – is what identifies a controller's firmware, so this is the way to attach to a controller that this process did not create (for example, firmware started by another application or a previous run). If this process already has a controller on the given node, that same controller is returned; otherwise the new controller occupies the first free controller index (see NumberGet()).
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
nodeNameThe INtime node name the firmware runs on ("NodeA", "NodeB", ...). nullptr or empty means the default node (CreationParameters::NodeNameDefault).
CreationParametersGet, INtimeNodeCountGet, INtimeNodeNameGet
