◆ NetworkNodeGet()
NetworkNode * NetworkNodeGet ( int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializes its internals.
nodeNumberThe reference number of the node. The first network node is the 0th Node.
(RapidCodeNetworkNode*) A pointer to the NetworkNode specified.
The RMP assigns a logical number to each network node that it encounters during initialization. This number starts with 0 and will be incremented for each node discovered.
Important usage instructions for all RapidCode creation methods: All creation methods, such as and Create(), AxisGet(), NetworkNodeGet(), etc. Each return valid pointers to RapidCode objects. These pointers are never null, even when there is an error during object creation.
Error Checking After Creation
Handling Errors
Helper Functions
Notes on creation methods with the C# API (vs. C++)
Object Cleanup Any and all objects created by RapidCode creation methods will be cleaned up by calling MotionController::Delete(). This should be done with your application is finished using RapidCode objects.
ErrorLogCountGet , ErrorLogGet , Delete , HelperFunctions.CheckErrors
InputOutput.cs, and PrintNetworkTopology.cpp.
