◆ MoveVelocity() [2/2]
void MoveVelocity ( double velocity,
double accel )
MoveVelocity command a constant velocity move (jog). The axis will accelerate to the Target velocity and continue indefinitely.
velocityTarget velocity, units/second.
accelMaximum accleration, units/second/second.
Non-Blocking Execution Motion commands return instantly and do not pause code execution. Use MotionDoneWait() post-call to halt execution until motion completes.
MoveVelocity
// Command a velocity move
axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
Motion Scope:
Velocity move (Trapezoidal type - 0% jerk) profile shown below:
Velocity Motion, MoveSCurve, MoveTrapezoidal, MovePT, MovePVT
