- Attention
 - See the following Concept pages for a detailed explanation of this sample: Feed Rate, S-Curve Motion.
- Warning
using NUnit.Framework;
using System;
using System.Threading;
[TestFixture]
[Category("Software")]
class MotionModify : SampleAppTestBase
  [Test]
  public void FeedRate()
    Console.WriteLine("Start Motion");
      Thread.Sleep(1);
    Console.WriteLine("New Feed Rate Start");
  public void ChangeMotionSpeed()
    axis.
MoveSCurve(20, Constants.VELOCITY, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT);
      axis.
MoveSCurve(20, Constants.VELOCITY * 10, Constants.ACCELERATION, Constants.DECELERATION, Constants.JERK_PERCENT);
double CommandPositionGet()
int32_t MotionDoneWait()
void Resume()
Resume an axis.
void FeedRateSet(double rate)
