movescurve-details
MoveSCurve command a point-to-point motion, with an S-Curve velocity profile. This type of motion has an "S" shape to the acceleration and deceleration phases. It uses the JerkPercent parameter to decide how much of the acceleration and deceleration phases is curved. A JerkPercent of zero produces a trapezoidal profile.
Part of the Motion method group. See the S-Curve Motion concept page for more information.
SCurveMotion
Motion Scope:
An S-Curve velocity (non-constant acceleration) profile shown below:
S-Curve Motion, MoveSCurve, MoveRelative, MoveVelocity, MovePT, MovePVT DefaultVelocitySet, DefaultAccelerationSet, DefaultDecelerationSet, DefaultJerkPercentSet
