Motion: Gantry
Gantry sample application.
This sample will configure two parallel axes (X1, X2) connected to the same load, and configure them so that X1 will be used to command linear motion, and X2 will be used to command yaw motion.
Precondition
#pragma region GantryDeclares
Axis *linearAxis;
Axis *yawAxis;
int linearAxisNumber = 0;
int yawAxisNumber = 1;
int defaultEncoderNumerator = 0; // 0 disables
int defaultEncoderDenominator = 0;
int gantryEncoderNumerator = 1; // we want 1/2
int gantryEncoderDenominator = 2;
double x1PrimaryCoeff = 1.0;
double x2PrimaryCoeff = 1.0;
double x1SecondaryCoeff = 1.0;
double x2SecondaryCoeff = -1.0;
double defaultPrimaryCoeff = 1.0;
double defaultSecondaryCoeff = 0.0;
uint64_t x1EncoderAddress;
uint64_t x2EncoderAddress;
uint64_t x1FilterPrimaryPointerAddress;
uint64_t x1FilterSecondaryPointerAddress;
uint64_t x2FilterPrimaryPointerAddress;
uint64_t x2FilterSecondaryPointerAddress;
uint64_t x1FilterPrimaryCoefficientAddress;
uint64_t x1FilterSecondaryCoefficientAddress;
uint64_t x2FilterPrimaryCoefficientAddress;
uint64_t x2FilterSecondaryCoefficientAddress;
uint64_t x1AxisLinkAddress;
uint64_t x2AxisLinkAddress;
#pragma endregion
#pragma region GantryMethods
void ReadAddressesFromMotionController()
x2EncoderAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeENCODER_PRIMARY);
x1FilterPrimaryPointerAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_POINTER);
x1FilterSecondaryPointerAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_POINTER);
x2FilterPrimaryPointerAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_POINTER);
x2FilterSecondaryPointerAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_POINTER);
x1FilterPrimaryCoefficientAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_COEFF);
x1FilterSecondaryCoefficientAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_COEFF);
x2FilterPrimaryCoefficientAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_COEFF);
x2FilterSecondaryCoefficientAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_COEFF);
x1AxisLinkAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeAXIS_LINK);
x2AxisLinkAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeAXIS_LINK);
void SetupEncoderMixing(bool enableGantry)
if (enableGantry)
// first scale encoders by half
linearAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, gantryEncoderNumerator, gantryEncoderDenominator);
yawAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, gantryEncoderNumerator, gantryEncoderDenominator);
mc->OS->Sleep(10);
// mix encoders (add on linear, subtract for yaw)
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x1EncoderAddress);
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x2EncoderAddress);
linearAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeADD);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x1EncoderAddress);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x2EncoderAddress);
linearAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, defaultEncoderNumerator, defaultEncoderDenominator);
yawAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, defaultEncoderNumerator, defaultEncoderDenominator);
mc->OS->Sleep(10);
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x1EncoderAddress);
linearAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeNONE);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x2EncoderAddress);
void SetupFilterMixing(bool enableGantry)
if (enableGantry)
// mix X1 filter
mc->MemorySet(x1FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
mc->MemorySet(x1FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// mix X2 filter
mc->MemorySet(x2FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
mc->MemorySet(x2FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// setup X1 filter mixing coefficients
mc->MemoryDoubleSet(x1FilterPrimaryCoefficientAddress, x1PrimaryCoeff);
mc->MemoryDoubleSet(x1FilterSecondaryCoefficientAddress, x1SecondaryCoeff);
// setup X2 filter mixing coefficients
mc->MemoryDoubleSet(x2FilterPrimaryCoefficientAddress, x2PrimaryCoeff);
mc->MemoryDoubleSet(x2FilterSecondaryCoefficientAddress, x2SecondaryCoeff);
// unmix X1 filter
mc->MemorySet(x1FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
// unmix X2 filter
mc->MemorySet(x2FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// setup X1 filter defult coefficients
mc->MemoryDoubleSet(x1FilterPrimaryCoefficientAddress, defaultPrimaryCoeff);
mc->MemoryDoubleSet(x1FilterSecondaryCoefficientAddress, defaultSecondaryCoeff);
// setup X2 filter default coefficients
mc->MemoryDoubleSet(x2FilterPrimaryCoefficientAddress, defaultPrimaryCoeff);
mc->MemoryDoubleSet(x2FilterSecondaryCoefficientAddress, defaultSecondaryCoeff);
void GantryEnable(bool enable)
ReadAddressesFromMotionController();
linearAxis->Abort();
yawAxis->Abort();
SetupEncoderMixing(enable);
SetupFilterMixing(enable);
linearAxis->ClearFaults();
linearAxis->AmpEnableSet(true);
yawAxis->ClearFaults();
yawAxis->AmpEnableSet(true);
#pragma endregion
void gantryMain()
// Create and initialize MotionController
// Get Axis X0 and X1 respectively.
linearAxis = mc->AxisGet(linearAxisNumber);
yawAxis = mc->AxisGet(yawAxisNumber);
//Only need once
//Enable when desired.
GantryEnable(true);
//Disable when finished.
GantryEnable(false);
@ RSIAxisAddressTypeAXIS_LINK
Axis Link for Gantry use.
Definition rsienums.h:478
@ RSIAxisAddressTypeENCODER_PRIMARY
Primary Encoder position.
Definition rsienums.h:467
@ RSIAxisAddressTypeFILTER_SECONDARY_POINTER
Filter Secondary Pointer for Gantry use.
Definition rsienums.h:474
@ RSIAxisAddressTypeFILTER_SECONDARY_COEFF
Filter Secondary Coefficient for Gantry use.
Definition rsienums.h:476
@ RSIAxisAddressTypeFILTER_PRIMARY_COEFF
Filter Primary Coefficient for Gantry use.
Definition rsienums.h:475
@ RSIAxisAddressTypeFILTER_PRIMARY_POINTER
Filter Primary Pointer for Gantry use.
Definition rsienums.h:473
@ RSIAxisPositionInputSECOND
Secondary encoder.
Definition rsienums.h:1276
@ RSIAxisPositionInputFIRST
Primary encoder.
Definition rsienums.h:1275
@ RSIMotorFeedbackPRIMARY
Primary encoder.
Definition rsienums.h:1295
