Motion: Gantry
Gantry sample application.
This sample will configure two parallel axes (X1, X2) connected to the same load, and configure them so that X1 will be used to command linear motion, and X2 will be used to command yaw motion.
Precondition
#pragma region GantryDeclares
Axis *linearAxis;
Axis *yawAxis;
int linearAxisNumber = 0;
int yawAxisNumber = 1;
int defaultEncoderNumerator = 0; // 0 disables
int defaultEncoderDenominator = 0;
int gantryEncoderNumerator = 1; // we want 1/2
int gantryEncoderDenominator = 2;
double x1PrimaryCoeff = 1.0;
double x2PrimaryCoeff = 1.0;
double x1SecondaryCoeff = 1.0;
double x2SecondaryCoeff = -1.0;
double defaultPrimaryCoeff = 1.0;
double defaultSecondaryCoeff = 0.0;
uint64_t x1EncoderAddress;
uint64_t x2EncoderAddress;
uint64_t x1FilterPrimaryPointerAddress;
uint64_t x1FilterSecondaryPointerAddress;
uint64_t x2FilterPrimaryPointerAddress;
uint64_t x2FilterSecondaryPointerAddress;
uint64_t x1FilterPrimaryCoefficientAddress;
uint64_t x1FilterSecondaryCoefficientAddress;
uint64_t x2FilterPrimaryCoefficientAddress;
uint64_t x2FilterSecondaryCoefficientAddress;
uint64_t x1AxisLinkAddress;
uint64_t x2AxisLinkAddress;
#pragma endregion
#pragma region GantryMethods
void ReadAddressesFromMotionController()
x1EncoderAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeENCODER_PRIMARY);
x2EncoderAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeENCODER_PRIMARY);
x1FilterPrimaryPointerAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_POINTER);
x1FilterSecondaryPointerAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_POINTER);
x2FilterPrimaryPointerAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_POINTER);
x2FilterSecondaryPointerAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_POINTER);
x1FilterPrimaryCoefficientAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_COEFF);
x1FilterSecondaryCoefficientAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_COEFF);
x2FilterPrimaryCoefficientAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_PRIMARY_COEFF);
x2FilterSecondaryCoefficientAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeFILTER_SECONDARY_COEFF);
x1AxisLinkAddress = linearAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeAXIS_LINK);
x2AxisLinkAddress = yawAxis->AddressGet(RSIAxisAddressType::RSIAxisAddressTypeAXIS_LINK);
void SetupEncoderMixing(bool enableGantry)
if (enableGantry)
// first scale encoders by half
linearAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, gantryEncoderNumerator, gantryEncoderDenominator);
yawAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, gantryEncoderNumerator, gantryEncoderDenominator);
mc->OS->Sleep(10);
// mix encoders (add on linear, subtract for yaw)
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x1EncoderAddress);
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x2EncoderAddress);
linearAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeADD);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x1EncoderAddress);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x2EncoderAddress);
yawAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeSUBTRACT);
linearAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, defaultEncoderNumerator, defaultEncoderDenominator);
yawAxis->EncoderRatioSet(RSIMotorFeedback::RSIMotorFeedbackPRIMARY, defaultEncoderNumerator, defaultEncoderDenominator);
mc->OS->Sleep(10);
linearAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputSECOND, x1EncoderAddress);
linearAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeNONE);
yawAxis->FeedbackPointerSet(RSIAxisPositionInput::RSIAxisPositionInputFIRST, x2EncoderAddress);
yawAxis->GantryTypeSet(RSIAxisGantryType::RSIAxisGantryTypeNONE);
void SetupFilterMixing(bool enableGantry)
if (enableGantry)
// mix X1 filter
mc->MemorySet(x1FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
mc->MemorySet(x1FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// mix X2 filter
mc->MemorySet(x2FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
mc->MemorySet(x2FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// setup X1 filter mixing coefficients
mc->MemoryDoubleSet(x1FilterPrimaryCoefficientAddress, x1PrimaryCoeff);
mc->MemoryDoubleSet(x1FilterSecondaryCoefficientAddress, x1SecondaryCoeff);
// setup X2 filter mixing coefficients
mc->MemoryDoubleSet(x2FilterPrimaryCoefficientAddress, x2PrimaryCoeff);
mc->MemoryDoubleSet(x2FilterSecondaryCoefficientAddress, x2SecondaryCoeff);
// unmix X1 filter
mc->MemorySet(x1FilterSecondaryPointerAddress, mc->FirmwareAddressGet(x1AxisLinkAddress));
// unmix X2 filter
mc->MemorySet(x2FilterPrimaryPointerAddress, mc->FirmwareAddressGet(x2AxisLinkAddress));
// setup X1 filter defult coefficients
mc->MemoryDoubleSet(x1FilterPrimaryCoefficientAddress, defaultPrimaryCoeff);
mc->MemoryDoubleSet(x1FilterSecondaryCoefficientAddress, defaultSecondaryCoeff);
// setup X2 filter default coefficients
mc->MemoryDoubleSet(x2FilterPrimaryCoefficientAddress, defaultPrimaryCoeff);
mc->MemoryDoubleSet(x2FilterSecondaryCoefficientAddress, defaultSecondaryCoeff);
void GantryEnable(bool enable)
ReadAddressesFromMotionController();
linearAxis->Abort();
yawAxis->Abort();
SetupEncoderMixing(enable);
SetupFilterMixing(enable);
linearAxis->ClearFaults();
linearAxis->AmpEnableSet(true);
yawAxis->ClearFaults();
yawAxis->AmpEnableSet(true);
#pragma endregion
void gantryMain()
// Create and initialize MotionController
mc = MotionController::CreateFromSoftware();
// Get Axis X0 and X1 respectively.
linearAxis = mc->AxisGet(linearAxisNumber);
yawAxis = mc->AxisGet(yawAxisNumber);
//Only need once
//Enable when desired.
GantryEnable(true);
//Disable when finished.
GantryEnable(false);
Definition rsi.h:5556
Definition rsi.h:795
