strong |
| Enumerator | |
| RSIFirmwareStatusIN_COARSE_POSITION | Bit 0 (0x01). Position error is within the coarse-position tolerance. |
| RSIFirmwareStatusAT_TARGET | Bit 1 (0x02). Latched. Command position has reached the profile target. |
| RSIFirmwareStatusAT_VELOCITY | Bit 2 (0x04). Command velocity has reached the requested cruise velocity. |
| RSIFirmwareStatusIN_FINE_POSITION | Bit 3 (0x08). Position error is within the fine (settling) tolerance. Same bit as SETTLED. |
| RSIFirmwareStatusSETTLED | Bit 3 (0x08). Alias for IN_FINE_POSITION. Axis has settled within fine tolerance. |
| RSIFirmwareStatusDONE | Bit 4 (0x10). Latched. Motion complete: profile finished (AT_TARGET) and settled (IN_FINE_POSITION). |
| RSIFirmwareStatusMOTION_START | Bit 5 (0x20). Latched. A new motion profile has started executing. |
| RSIFirmwareStatusMOTION_MODIFY | Bit 6 (0x40). Latched. A running motion profile was modified (e.g., new target appended). |
| RSIFirmwareStatusPS_FAULT | Bit 7 (0x80). Program Sequencer fault. N/A. |
| RSIFirmwareStatusMS_FAULT | Bit 8 (0x100). Motion Supervisor fault. |
| RSIFirmwareStatusOUT_OF_FRAMES | Bit 9 (0x200). Latched. Motion frame buffer underrun — host did not supply frames fast enough. |
| RSIFirmwareStatusFRAME | Bit 10 (0x400). A motion frame has been consumed (loaded into execution). |
| RSIFirmwareStatusRESET | Bit 11 (0x800). Axis has been reset (faults cleared). |
| RSIFirmwareStatusRESUME | Bit 12 (0x1000). Motion resumed from a paused or stopped state. |
| RSIFirmwareStatusPAUSE | Bit 13 (0x2000). Motion is paused — ramping feedrate to zero velocity, resumable. |
| RSIFirmwareStatusSTOP | Bit 14 (0x4000). Latched. Motion has been stopped. Must be explicitly resumed or cleared. |
| RSIFirmwareStatusESTOP | Bit 15 (0x8000). Latched. Emergency stop — ramping feedrate to zero on the E-Stop profile. |
| RSIFirmwareStatusESTOP_ABORT | Bit 16 (0x10000). Latched. E-Stop followed by command position set to actual position. |
| RSIFirmwareStatusESTOP_CMD_EQ_ACT | Bit 17 (0x20000). Latched. E-Stop with immediate command-equals-actual snap. |
| RSIFirmwareStatusTRIGGERED_MODIFY_ESTOP | Bit 18 (0x40000). Latched. A triggered modify resulted in an E-Stop. |
| RSIFirmwareStatusTRIGGERED_MODIFY | Bit 19 (0x80000). Latched. A triggered modify action has fired (motion modified by event). |
| RSIFirmwareStatusABORT | Bit 20 (0x100000). Latched. Motion aborted — command position immediately set to actual. |
| RSIFirmwareStatusERROR_STATE | Bit 21 (0x200000). Latched. Derived — automatically set when any error bit (15–18, 20) is active. |
| RSIFirmwareStatusDISABLED | Bit 22 (0x400000). Amp enable output is OFF — the axis is disabled. |
| RSIFirmwareStatusHOST | Bit 23 (0x800000). Latched. The current stop/error was initiated by the host application (user), not the firmware. Cleared when motion resumes. |
| RSIFirmwareStatusREC_IDLE | Bit 24 (0x1000000). Data recorder is idle (not recording). |
| RSIFirmwareStatusREC_HIGH | Bit 25 (0x2000000). Data recorder buffer has reached the high-water mark. |
| RSIFirmwareStatusREC_FULL | Bit 26 (0x4000000). Data recorder buffer is completely full. |
| RSIFirmwareStatusREC_RUNNING | Bit 27 (0x8000000). Data recorder is actively recording samples. |
| RSIFirmwareStatusCAM | Bit 28 (0x10000000). Electronic cam error — master axis fault propagated to this follower. |
| RSIFirmwareStatusEXTERNAL | Bit 29 (0x20000000). External event — a User Message command executed in the Program Sequencer. N/A. |
| RSIFirmwareStatusTRIGGERED_MODIFY_ESTOP_ABORT | Bit 30 (0x40000000). Latched. A triggered modify resulted in an E-Stop with abort. |
| RSIFirmwareStatusMOTOR_LIMIT | Bit 31 (0x80000000). Latched. A motor limit condition fired (amp fault, encoder fault, HW/SW limit, error limit, or torque limit). Read RSIAxisAddressTypeMOTOR_DATA_STATUS to identify which. |
Definition at line 529 of file rsienums.h.
