◆ RSIErrorMessage
enum class RSIErrorMessage
strong
Enumerator
RSIAxisMessageAXIS_INVALID
RSIAxisMessageCOMMAND_NOT_SET
RSIAxisMessageNOT_MAPPED_TO_MS
RSICaptureMessageMOTOR_INVALID
RSICaptureMessageCAPTURE_TYPE_INVALID
RSICaptureMessageCAPTURE_INVALID
RSICaptureMessageFEEDBACK_INVALID
RSICaptureMessageINVALID_EDGE
RSICaptureMessageCAPTURE_NOT_ENABLED
RSICaptureMessageCAPTURE_STATE_INVALID
RSICaptureMessageUNSUPPORTED_PRIMARY
RSICaptureMessageUNSUPPORTED_SECONDARY
RSICaptureMessageCAPTURE_ARMED
RSICommandMessageTYPE_INVALID
RSICompensatorMessageCOMPENSATOR_INVALID
RSICompensatorMessageNOT_CONFIGURED
RSICompensatorMessageNOT_ENABLED
RSICompensatorMessageAXIS_NOT_ENABLED
RSICompensatorMessageTABLE_SIZE_ERROR
RSICompensatorMessagePOSITION_DELTA_INVALID
RSICompensatorMessageDIMENSION_NOT_SUPPORTED
RSIControlMessageLIBRARY_VERSION
RSIControlMessageCONTROL_INVALID
RSIControlMessageCONTROL_NUMBER_INVALID
RSIControlMessageTYPE_INVALID
RSIControlMessageINTERRUPTS_DISABLED
RSIControlMessageINTERNAL_MEMORY_OVERFLOW
RSIControlMessageEXTERNAL_MEMORY_OVERFLOW
RSIControlMessageBACKGROUND_STARVATION
RSIControlMessageMOTOR_COUNT_INVALID
RSIControlMessageFILTER_COUNT_INVALID
RSIControlMessageAXIS_COUNT_INVALID
RSIControlMessageAXIS_FRAME_COUNT_INVALID
RSIControlMessageMOTION_COUNT_INVALID
RSIControlMessageMATH_BLOCK_COUNT_INVALID
RSIControlMessageSEQUENCE_COUNT_INVALID
RSIControlMessagePRE_FILTER_DELAY_COUNT_INVALID
RSIControlMessageRECORDER_COUNT_INVALID
RSIControlMessageLIMIT_BLOCK_COUNT_INVALID
RSIControlMessageCOMPENSATOR_COUNT_INVALID
RSIControlMessageCAPTURE_COUNT_INVALID
RSIControlMessageTX_TIME_INVALID
RSIControlMessageSAMPLE_RATE_TO_LOW
RSIControlMessageSAMPLE_RATE_TO_HIGH
RSIControlMessageAXIS_RUNNING
RSIControlMessageRECORDER_RUNNING
RSIControlMessagePACK_ALIGNMENT
RSIControlMessageFIRMWARE_INVALID
RSIControlMessageFIRMWARE_VERSION_NONE
RSIControlMessageNO_FPGA_SOCKET
RSIControlMessageSYNQNET_STATE
RSIControlMessageIO_BIT_INVALID
RSIControlMessageOBJECT_INDEX_INVALID
RSIControlMessageOBJECT_INVALID
RSIControlMessageFLASH_SYNQNET_STATE_INVALID
RSIControlMessageFLASH_INVALID
RSIControlMessageFLASH_VERIFY_ERROR
RSIControlMessageFLASH_WRITE_ERROR
RSIControlMessageFILE_INACCESSIBLE
RSIControlMessageBUFFER_TOO_SMALL
RSIControlMessageEVENTS_LOST
RSIElementMessageELEMENT_INVALID
RSIEventMessageEVENT_INVALID
RSIFilterMessageFILTER_INVALID
RSIFilterMessageINVALID_ALGORITHM
RSIFilterMessageINVALID_DRATE
RSIFilterMessageCONVERSION_DIV_BY_0
RSIFilterMessageSECTION_NOT_ENABLED
RSIFilterMessageINVALID_FILTER_FORM
RSIFilterMessageINVALID_SMOOTHING
RSIGeometricPathMessageILLEGAL_DIMENSION
RSIGeometricPathMessageILLEGAL_ELEMENT
RSIGeometricPathMessageARC_ILLEGAL_DIMENSION
RSIGeometricPathMessageILLEGAL_RADIUS
RSIGeometricPathMessagePATH_TOO_LONG
RSIGeometricPathMessageUNSUPPORTED_TYPE
RSIGeometricPathMessageILLEGAL_VELOCITY
RSIGeometricPathMessageILLEGAL_ACCELERATION
RSIGeometricPathMessageILLEGAL_TIMESLICE
RSILicenseMessageNOT_VALID
RSILicenseMessageNOFEATURE
RSILicenseMessageNOAXIS
RSILicenseMessageCONTROL_TYPE_FILE
RSILicenseMessageEXPIRED
RSILicenseMessageUNLICENSED
RSILicenseMessageNO_APP_LICENSE
RSIListMessageELEMENT_NOT_FOUND
RSIListMessageELEMENT_INVALID
RSIMessageOK
RSIMessageARG_INVALID
RSIMessagePARAM_INVALID
RSIMessageHANDLE_INVALID
RSIMessageNO_MEMORY
RSIMessageOBJECT_FREED
RSIMessageOBJECT_NOT_ENABLED
RSIMessageOBJECT_NOT_FOUND
RSIMessageOBJECT_ON_LIST
RSIMessageOBJECT_IN_USE
RSIMessageTIMEOUT
RSIMessageUNSUPPORTED
RSIMessageFATAL_ERROR
RSIMessageFILE_CLOSE_ERROR
RSIMessageFILE_OPEN_ERROR
RSIMessageFILE_READ_ERROR
RSIMessageFILE_WRITE_ERROR
RSIMessageFILE_MISMATCH
RSIMessageASSERT_FAILURE
RSIClientMessageMETHOD_INVALID
RSIClientMessageHEADER_INVALID
RSIClientMessageRSICONSTANT_INCOMPATIBLE
RSIClientMessageSERVER_INCOMPATIBLE
RSIClientMessageSERVER_INACCESSIBLE
RSIClientMessageCOUNT
RSIMotionMessageMOTION_INVALID
RSIMotionMessageAXIS_COUNT
RSIMotionMessageAXIS_FRAME_COUNT
RSIMotionMessageTYPE_INVALID
RSIMotionMessageATTRIBUTE_INVALID
RSIMotionMessageIDLE
RSIMotionMessageMOVING
RSIMotionMessageSTOPPING
RSIMotionMessageSTOPPED
RSIMotionMessageSTOPPING_ERROR
RSIMotionMessageERROR
RSIMotionMessageAUTO_START
RSIMotionMessageILLEGAL_DELAY
RSIMotionMessagePROFILE_ERROR
RSIMotionMessagePROFILE_NOT_SUPPORTED
RSIMotionMessagePATH_ERROR
RSIMotionMessageFRAMES_LOW
RSIMotionMessageFRAMES_EMPTY
RSIMotionMessageFRAME_BUFFER_OVERRUN
RSIMotionMessageRESERVED0
RSIMotionMessageRESERVED1
RSIMotionMessageRESERVED2
RSIMotionMessageNO_AXES_MAPPED
RSIMotionMessageBAD_PATH_DATA
RSIMotionMessageAXIS_MOVING
RSIMotionMessageAXIS_MAP_MISMATCH
RSIMotorMessageMOTOR_INVALID
RSIMotorMessageTYPE_INVALID
RSIMotorMessageSTEPPER_NA
RSIMotorMessageMOTOR_NOT_ENABLED
RSIMotorMessageSECONDARY_FEEDBACK_NA
RSIMotorMessageHARDWARE_NOT_FOUND
RSIMotorMessageSTEPPER_INVALID
RSIMotorMessageDISABLE_ACTION_INVALID
RSIMotorMessagePULSE_WIDTH_INVALID
RSIMotorMessageFEEDBACK_REVERSAL_NA
RSIMotorMessagePHASE_FINDING_FAILED
RSIMotorMessageDEMAND_MODE_UNSUPPORTED
RSIMotorMessageDEMAND_MODE_NOT_SET
RSIMotorMessagePOSITION_FEEDBACK_OFFSET_UNSUPPORTED
RSIMotorMessagePOSITION_FEEDBACK_OFFSET_SET_FAILED
RSIMotorMessagePOSITION_FEEDBACK_OFFSET_UNINITIALIZED
RSIMapMessageNAME_INVALID
RSIMapMessageNAME_NOT_FOUND
RSIMapMessageINDEX_INVALID
RSIMapMessageFILE_INVALID
RSIMapMessageSYMBOL_NOT_FOUND
RSIMapMessageSYMBOL_INVALID
RSIThreadMessageTHREAD_NOT_RUNNING
RSIThreadMessageTHREAD_RUNNING
RSIThreadMessageTHREAD_NOT_STARTED
RSINotifyMessageWAIT_IN_PROGRESS
RSIPacketMessageADDRESS_INVALID
RSIPacketMessageCOMM_ERROR
RSIPacketMessageCONNECTION_CLOSED
RSIPlatformMessagePLATFORM_INVALID
RSIPlatformMessageDEVICE_INVALID
RSIPlatformMessageDEVICE_ERROR
RSIPlatformMessageDEVICE_MAP_ERROR
RSIPlatformMessageCOPY64_FAILURE
RSIPlatformMessagePATH_DOES_NOT_EXIST
RSIPlatformMessagePATH_IS_NOT_A_DIRECTORY
RSIPlatformMessageINSTALL_VARIABLE_NOT_SET
RSIPlatformMessageDRIVER_VERSION_INCOMPATIBLE
RSIPlatformMessageFILE_TYPE_INVALID
RSIPlatformMessageFILE_VERSION
RSIPlatformMessageUSER_IS_NOT_ADMIN
RSIPlatformMessageINTIME_VERSION_UNSUPPORTED
RSIPlatformMessageINTIME_NODE_DOES_NOT_EXIST
RSIPlatformMessageINTIME_NOT_STARTED
RSIPlatformMessageRMP_NOT_STARTED
RSIPlatformMessageRSI_LICENSE_NOT_FOUND
RSIPlatformMessageRSI_LICENSE_INVALID
RSIPlatformMessageRSI_USB_SERIAL_NOT_FOUND
RSIRecorderMessageSTARTED
RSIRecorderMessageSTOPPED
RSIRecorderMessageNOT_CONFIGURED
RSIRecorderMessageNO_RECORDERS_AVAIL
RSIRecorderMessageNOT_ENABLED
RSIRecorderMessageRUNNING
RSIRecorderMessageRECORD_COUNT_INVALID
RSIRecorderMessageRESERVED
RSIRecorderMessageNOT_RESERVED
RSIServerMessageMETHOD_INVALID
RSIServerMessageHEADER_INVALID
RSIUserLimitMessageUSER_LIMIT_INVALID
RSI_CONTROLLER_INVALID_CONTROLLER_NUMBER
Invalid controller number.
RSI_CONTROLLER_INVALID_SERVER_NAME
Invalid server name for CLIENT controller.
RSI_CONTROLLER_INVALID_CONTROLLER_TYPE
Invalid controller type.
RSI_INVALID_ID
Invalid RSI ID.
RSI_CONTROLLER_NOT_SYNC_INTERRUPT
Not the controller Sync interrupt.
RSI_CONTROLLER_CUSTOM_FIRMWARE_REQUIRED
Custom controller firmware required.
RSI_AXIS_HOME_METHOD_NOT_SUPPORTED
Home Method not (yet) supported.
RSI_AXIS_HOME_CAPTURE_FAILED
Capture failed.
RSI_AXIS_HOME_CAPTURE_ARMING_FAILED
Capture failed to arm for homing.
RSI_AXIS_HOME_INVALID_HOME_VELOCITY
Invalid Home Velocity.
RSI_AXIS_HOME_INVALID_HOME_SLOW_VELOCITY
Invalid Home Slow Velocity.
RSI_AXIS_HOME_INVALID_HOME_ACCELERATION
Invalid Home Acceleration.
RSI_AXIS_HOME_INVALID_HOME_DECELERATION
Invalid Home Deceleration.
RSI_AXIS_HOME_CANCELED
User canceled homing operation.
RSI_AXIS_HOME_FAILED_TO_REACH_DESIRED_STATE_OF_SWITCH
Homing failed to reach the desired state of a switch.
RSI_FUNCTION_NOT_SUPPORTED
This method is not currently supported.
RSI_ERROR_LOG_EMPTY
The error log is empty.
RSI_ERROR_LOG_FULL
The error log is full.
RSI_SQNODE_NOT_IO_NODE
This node is not an I/O node.
RSI_AXIS_ADDRESS_TYPE_UNKNOWN
The address type requested is unknown or unsupported.
RSI_METHOD_UNSUPPORTED
This method is not supported in this version.
RSI_MOTION_DONE_WAIT_TIMEOUT
Timed out while waiting for MotionDone.
RSI_ERROR_MESSAGE_DYNAMIC
The text for this error will be dynamically generated in the source code.
RSI_NETWORK_FIRMWARE_IS_BUSY
The network firmware is busy.
RSI_CONTROLLER_INVALID_UNHANDLED
The controller is invalid due to prior failure.
RSI_STREAMING_OUTPUT_CONFIG_INVALID
The number of streaming output values must be configured with StreamingOutputCountSet before adding outputs.
RSI_AXIS_HOME_FAILED_TO_REACH_MAX_TRAVEL
Failed to reached State in specified Max Travel. Please evaluate limits or Stage's Max Travel value.
RSI_AXIS_HOME_UNEXPECTED_STATE
Expected STOPPED state but didn't reach it. Homing requires Home/Hardware Limit actions set to STOP.
RSI_AXIS_HOME_INVALID_POS_LIMIT_HIT
Hit Positive Limit while moving to Negative Limit.
RSI_AXIS_HOME_INVALID_NEG_LIMIT_HIT
Hit Negative Limit while moving to Positive Limit.
RSI_AXIS_LIMIT_UNEXPECTED_STATE
Expected True and was False or vise versa.
RSI_AXIS_RISING_HOME_STATE_HIGH_CHECK
Failed to reach expected Home State: High. This method should only be used for Home Setups which are High to the Positive Limit.
RSI_AXIS_RISING_HOME_STATE_LOW_CHECK
Failed to reach expected Home State: Low. This method should only be used for Home Setups which are High to the Positive Limit.
RSI_AXIS_FALLING_HOME_STATE_HIGH_CHECK
Failed to reach expected Home State: High. This method should only be used for Home Setups which are High to the Negative Limit.
RSI_AXIS_FALLING_HOME_STATE_LOW_CHECK
Failed to reach expected Home State: Low. This method should only be used for Home Setups which are High to the Negative Limit.
RSI_AXIS_HOME_INDEX_NOT_SUPPORTED
Home Methods which require Index are only selectively supported. Contact RSI to see if we can add support for your hardware.
RSI_AXIS_HOME_INDEX_NOT_REACHABLE
Distance to Travel to Index (AKDs Zero Angle) is greater than Home Stage Max Travel. Skipping Motion. Please evaluate your Stage Max Travel.
RSI_AXIS_HOME_INDEX_NOT_REACHED
Did not finish in IDLE state after attempting to move to Zero Angle.
RSI_NETWORK_NODE_DOES_NOT_EXIST
NetworkNode object does not exist.
RSI_COMPENSATOR_POINT_COUNT_INVALID
Memory allocated for compensator not equal to required.
RSI_COMPENSATOR_COULD_NOT_DISABLE_SINGLE
The compensator could not be disabled.
RSI_COMPENSATOR_COULD_NOT_ENABLE_ADDITIVE
The compensator could not be enabled.
RSI_COMPENSATOR_INVALID_AXIS_MASTER_TYPE
The compensator config was invalid.
RSI_COMPENSATOR_COULD_NOT_ENABLE_AXIS_ACTUAL_POSITION
RSI_IOPOINT_INVALID_OUTPUT
An output was configured as an input.
RSI_FIRMWARE_VERSION_MISMATCH
The RMP firmware and the RapidCode software versions don't match. Restart your INtime Node.
RSI_NOFEATURE_LICENSE
The RMP feature is not enabled.
RSI_GCODE_PARSE
Error interpreting the G-Code string.
RSI_GCODE
Generic type for RSI specific G-Code errors.
RSI_GCODE_LINE
Generic type for RSI specific G-Code errors occurring on a specific line or move.
RSI_GCODE_SYNTAX
G-Code Syntax parsing errors.
RSI_EXECUTOR
Exception while running the Cartesian trajectory executor.
RSI_CARTESIAN_TRAJECTORY_BUILDER
Error while trying to build the Cartesian trajectory before running it.
RSI_CARTESIAN_PATH
Cartesian move builder exception.
RSI_CARTESIAN_PATH_LINE
Cartesian move builder exception occurring on a specific line or move.
RSI_CARTESIAN_ROBOT
Robot errors.
RSINetworkNodeMessageNODE_FAILURE
EtherCAT node failure.
RSI_MATHBLOCK_INVALID
Invalid MathBlock.
MotionController::MathBlockCountSet()
RSI_AMP_ENABLE_RESTRICTED_STATE
Failed attempt to enable amplifier in a restricted state (MOVING, STOPPING, STOPPED) see RapidCodeMotion::AmpEnableSet().
Definition at line 17 of file rsienums.h.
