| Enumerator |
| RSIHomeMethodNONE | Set the current position to zero (home)  |
| RSIHomeMethodNEGATIVE_LIMIT_THEN_RIGHT_INDEX |
| RSIHomeMethodPOSITIVE_LIMIT_THEN_LEFT_INDEX |
| RSIHomeMethodRISING_HOME_THEN_LEFT_INDEX |
| RSIHomeMethodRISING_HOME_THEN_RIGHT_INDEX |
| RSIHomeMethodFALLING_HOME_THEN_RIGHT_INDEX |
| RSIHomeMethodFALLING_HOME_THEN_LEFT_INDEX |
| RSIHomeMethodRISING_HOME_THEN_LEFT_INDEX_POSITIVE_START |
| RSIHomeMethodRISING_HOME_THEN_RIGHT_INDEX_POSITIVE_START |
| RSIHomeMethodFALLING_HOME_THEN_LEFT_INDEX_POSITIVE_START |
| RSIHomeMethodFALLING_HOME_THEN_RIGHT_INDEX_POSITIVE_START |
| RSIHomeMethodFALLING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START |
| RSIHomeMethodFALLING_HOME_THEN_LEFT_INDEX_NEGATIVE_START |
| RSIHomeMethodRISING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START |
| RSIHomeMethodRISING_HOME_THEN_LEFT_INDEX_NEGATIVE_START |
| RSIHomeMethodRESERVED_15 |
| RSIHomeMethodRESERVED_16 |
| RSIHomeMethodNEGATIVE_LIMIT |
| RSIHomeMethodPOSITIVE_LIMIT |
| RSIHomeMethodRISING_HOME |
| RSIHomeMethodFALLING_HOME |
| RSIHomeMethodRISING_HOME_POSITIVE_START |
| RSIHomeMethodFALLING_HOME_POSITIVE_START |
| RSIHomeMethodFALLING_HOME_NEGATIVE_START |
| RSIHomeMethodRISING_HOME_NEGATIVE_START |
| RSIHomeMethodRESERVED_31 | Reserved.  |
| RSIHomeMethodRESERVED_32 | Reserved.  |
| RSIHomeMethodINDEX_NEGATIVE_START |
| RSIHomeMethodINDEX_POSITIVE_START |
| RSIHomeMethodCURRENT_POSITION |
| RSIHomeMethodNEGATIVE_HARDSTOP | Negative Hardstop.  |
| RSIHomeMethodPOSITIVE_HARDSTOP | Positive Hardstop.  |
| RSIHomeMethodImprovedNone | None.  |
| RSIHomeMethodImprovedNEGATIVE_LIMIT_THEN_RIGHT_INDEX |
| RSIHomeMethodImprovedPOSITIVE_LIMIT_THEN_LEFT_INDEX |
| RSIHomeMethodImprovedRISING_HOME_THEN_LEFT_INDEX |
| RSIHomeMethodImprovedRISING_HOME_THEN_RIGHT_INDEX |
| RSIHomeMethodImprovedFALLING_HOME_THEN_RIGHT_INDEX |
| RSIHomeMethodImprovedFALLING_HOME_THEN_LEFT_INDEX |
| RSIHomeMethodImprovedRISING_HOME_THEN_LEFT_INDEX_POSITIVE_START |
| RSIHomeMethodImprovedRISING_HOME_THEN_RIGHT_INDEX_POSITIVE_START |
| RSIHomeMethodImprovedFALLING_HOME_THEN_LEFT_INDEX_POSITIVE_START |
| RSIHomeMethodImprovedFALLING_HOME_THEN_RIGHT_INDEX_POSITIVE_START |
| RSIHomeMethodImprovedFALLING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START |
| RSIHomeMethodImprovedFALLING_HOME_THEN_LEFT_INDEX_NEGATIVE_START |
| RSIHomeMethodImprovedRISING_HOME_THEN_RIGHT_INDEX_NEGATIVE_START |
| RSIHomeMethodImprovedRISING_HOME_THEN_LEFT_INDEX_NEGATIVE_START |
| RSIHomeMethodImprovedRESERVED_115 |
| RSIHomeMethodImprovedRESERVED_116 |
| RSIHomeMethodImprovedNEGATIVE_LIMIT |
| RSIHomeMethodImprovedPOSITIVE_LIMIT |
| RSIHomeMethodImprovedPOSITIVE_HOME_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedPOSITIVE_HOME_POSITIVE_MOMENTUM |
| RSIHomeMethodImprovedNEGATIVE_HOME_POSITIVE_MOMENTUM |
| RSIHomeMethodImprovedNEGATIVE_HOME_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedRISING_HOME_POSITIVE_START_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedRISING_HOME_POSITIVE_START_POSITIVE_MOMENTUM |
| RSIHomeMethodImprovedFALLING_HOME_POSITIVE_START_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedFALLING_HOME_POSITIVE_START_POITIVE_MOMENTUM |
| RSIHomeMethodImprovedFALLING_HOME_NEGATIVE_START_POSITIVE_MOMENTUM |
| RSIHomeMethodImprovedFALLING_HOME_NEGATIVE_START_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedRISING_HOME_NEGATIVE_START_POSITIVE_MOMENTUM |
| RSIHomeMethodImprovedRISING_HOME_NEGATIVE_START_NEGATIVE_MOMENTUM |
| RSIHomeMethodImprovedRESERVED_131 |
| RSIHomeMethodImprovedRESERVED_132 |
| RSIHomeMethodImprovedNEGATIVE_INDEX |
| RSIHomeMethodImprovedPOSITIVE_INDEX |
| RSIHomeMethodImprovedCURRENT_POSITION |
| RSIHomeMethodImprovedNEGATIVE_HARDSTOP |
| RSIHomeMethodImprovedPOSITIVE_HARDSTOP |
