General Purpose IO
Utilize general-purpose IO for versatile digital and analog input/output control across the EtherCAT network.
🔹 What are general-purpose IOs?
In the RapidCode API, when we use the term IO, we mean general-purpose digital inputs or digital outputs and analog inputs or analog outputs.
General-purpose IOs are typically connected to the EtherCAT network via slave module. Click to see the hardware list.
Here is a picture of RapidSetupX showing all available general purpose IO in the system's network:
RapidSetupX: IO Page
To control dedicated IO on the drive such as: Home, Positive Limit, Negative Limit, etc. Please navigate to Dedicated IO topic documentation.
🔹 How do I get/set general-purpose IOs?
There are two ways to access general purpose digital/analog inputs/outputs:
  1. Via the NetworkNode object (recommended):
    // get node
    // digital io
    bool dIn = node.DigitalInGet(digitalInNumber: 0);
    bool dOut = node.DigitalOutGet(digitalOutNumber: 0);
    node.DigitalOutSet(digitalOutNumber: 0, state: dOut);
    // analog io
    int aIn = node.AnalogInGet(analogChannel: 0);
    int aOut = node.AnalogOutGet(analogChannel: 0);
    node.AnalogOutSet(analogChannel: 0, analogValue: aOut);
  2. Via the IOPoint object: check out the IOPoint concept page.
