◆ FeedbackPointerSet()
void FeedbackPointerSet ( RSIAxisPositionInput input,
uint64_t address )
FeedbackPointerSet sets an axis configuration for dual-loop operation. Before you can use dual-loop, an Axis must be set to use filter type RSIFilterAlgorithmPIV - FilterAlgorithmSet()
input– always select RSIAxisPositionInput.RSIAxisPositionInputFIRST
address– which host address to use for the encoder to use when closing position loop
// configure an axis for dual loop control
axis1.FeedbackPointerSet(RSIAxisPositionInput.RSIAxisPositionInputFIRST, axis2.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeENCODER_PRIMARY));
Definition rsienums.h:439
Feedback Positions for each Axis.
Definition rsienums.h:1182
DualLoop
