10.6.0
RapidSetup Menu
Table of Contents
🔹 File
🔹 View
🔹 Tools
🔹 INtime
🔹 Help
The RapidSetup menu bar.
🔹 File
Open Working DIrectory
allows you to open the directory where RapidSetup is running. It contains all the RapidCode files: RSI.dll, rsi.lic, etc.
Save Memory Dump to File
allows you to save your RMP controller's memory to a file. Use DumpDiff.exe to compare memory dumps.
Exit
will close the RapidSetup application.
🔹 View
Refresh
will allow you to initialize the RMP MotionController and refresh the view of RapidSetup.
Network Data
is a
page
that allows you to observe the exchanged network PDO inputs and outputs.
Network IO
is a
page
that allows you to observe the network IO.
Error Messages
will open the
error message
window.
Network Timing Window
will open a
window
that you can use to measure EtherCAT network packet timing.
Packet Errors
will open a
window
that you can use to view packet errors for each EtherCAT port for every EtherCAT node.
Expert Mode
enables multiple different fields within RapidSetup such as:
Tuning Tab on Axis Page
Start Network to PreOperational Button on RMP MotionController Page
Setting Command Position and Origin Position on Axis Page
Opening
Folder on File menu item
🔹 Tools
VM3
is a
GUI
designed for advanced users to view RMP firmware memory directly.
MotionScope
is a GUI that allows you to record and display up to 32 traces.
RapidWorkbench
is a GUI created by Kollmorgen to configure their AKD drives.
🔹 INtime
Start
allows you to start your INtime nodeA/nic connection.
Stop
allows you to stop your INtime nodeA/nic connection.
Restart
allows you to restart your INtime nodeA/nic connection.
🔹 Help
RapidPortal
will open our
RapidPortal
website.
Documentation
will open our
RapidSetup
online user manual.
Send us an email
will allow you to contact us for any questions or concerns.
About
will display the version of RapidSetup you are using.
1.10.0
