Learn how to use RapidSetup with follow-through tutorials.
🔹 Starting the Network
Get your RMP motion controller and EtherCAT network up and running.
STEPS:
- Discover the nodes on the network.
- Make sure a valid ENI file has been created.
- Start the Network.
🔹 Reading Tooltips
Use RapidSetup tooltips to learn more about our RapidCode API.
STEPS:
- Hover over desired field
NOTES:
- Labels display RapidCode API getters in most cases.
- Textboxes display RapidCode API setters in most cases.
- Read-Only Textboxes will vary or not display anything.
- Buttons display RapidCode API actions/functions in most cases.
We say "in most cases" because some fields might not be related to our RapidCode API.
🔹 Renaming Tree View Items
Use this functionality to give a better name to some of your tree view items.
STEPS:
- Right click an Axis, IO, or MultiAxis tree view item.
- Select "Rename" from context menu.
- Click inside the TextBox.
- Edit the name.
- Click enter or loose focus to save.
NOTES:
- Labels have a maximum of 16 characters.
🔹 Subsections
