PT Streaming Motion
PT motion is the simplest streaming motion requiring only Positions and Time deltas arrays.
🔹 What is PT Motion?
PT motion is the simplest streaming motion to use because it only requires an array of Positions and Time deltas. The controller is responsible for figuring out the velocity, and acceleration for each motion segment. MovePT currently supports several types of interpolation, as described in Streaming Motion.
Simple PT Interpolation Output Example
RSIMotionTypePT is good for very closely spaced points (int time) or low accelerations. It is a very simple algorithm, requiring very few calculations; therefore, it is fast. If the points are spaced too far apart, the motion will be rough like shown in the example below. The acceleration between each point is instantaneous. It is best to keep the point spacing within a few samples.
Trapezoidal move example:
p1[0] = 050; t1[0] = 1.0;
p1[1] = 400; t1[1] = 3.5;
p1[2] = 450; t1[2] = 1.0;
Note: The Position array is direction sensitive meaning you must put a (-) sign on negative numbers.
BSpline Interpolation Output Example
RSIMotionTypeBSPLINE interpolation is our recommended technique to blend transitions between segments. Use BSpline for smooth paths or systems with poor acceleration response.
p[0] = 050; t[0] = 1.0;
p[1] = 400; t[1] = 3.5;
p[2] = 450; t[2] = 1.0;
🔹 PT Motion with Feedforward (PTF)
MovePTF extends PT motion by adding a feedforward term to each point. The feedforward value is a raw control output value applied directly to the control output, providing additional control authority beyond the PID controller.
When to Use Feedforward
Feedforward is useful when you need to compensate for known forces or apply model-based control:
  • Gravity Compensation: For vertical axes, apply a constant feedforward to counteract gravitational force
  • Friction Compensation: Add feedforward values to overcome static or dynamic friction
  • Torque Feedforward: Provide additional torque for high-performance applications or dynamic loads
  • Model-Based Control: Apply control outputs calculated from system dynamics models
Feedforward Units and Configuration
Feedforward values are raw control output values, not UserUnits:
  • Typically 16-bit signed integers for torque control (-32768 to 32767)
  • Typically 32-bit signed integers for velocity or position control
  • The axis must be configured separately for the output type and PDO mapping via demand channel configuration
Feedforward Interpolation
The feedforward values are linearly interpolated between consecutive points during multi-sample segments:
  • If a segment spans 10 firmware samples, the feedforward transitions smoothly by 10% per sample from the current point to the next
  • For single-sample segments, the feedforward changes instantly at each point
Array Structure for PTF
For single Axis:
positions[] = [p₀, p₁, p₂, ..., pₙ]
times[] = [t₀, t₁, t₂, ..., tₙ]
feedforwards[] = [f₀, f₁, f₂, ..., fₙ] // raw control output values
For MultiAxis with 3 axes:
positions[] = [X₀, Y₀, Z₀, X₁, Y₁, Z₁, ..., Xₙ, Yₙ, Zₙ]
times[] = [t₀, t₁, ..., tₙ]
feedforwards[] = [Xf₀, Yf₀, Zf₀, Xf₁, Yf₁, Zf₁, ..., Xfₙ, Yfₙ, Zfₙ]
The feedforwards array size must match the positions array size.
🔹 MultiAxis PT Motion
All motion streaming methods can be used for coordinated motion on MultiAxis objects. It is important that you setup your arrays appropriately for a MultiAxis object. See the examples below on how to structure your arrays for MultiAxis PT Motion.
Example 1: Three Axis Multi-Axis XYZ with MovePT
The position data for all three axes are combined into the array. The time array is shared for all axes. This is why you need 3x as many position points than you need time points. See the example below:
p[0] = 050; t[0] = 1;
p[1] = 025;
p[2] = 012.5;
p[3] = 400; t[1] = 3.5;
p[4] = 200;
p[5] = 100;
p[6] = 450; t[2] = 1;
p[7] = 225;
p[8] = 112.5;
1st Segment 2nd Segment 3rd Segment Resulting Motion Plot
AxisX p[0] = 050;
[0] = 1;
p[2] = 400;
t[1] = 3.5;
p[4] = 450;
t[2] = 1;
AxisY p[1] = 025;
t[0] = 1;
p[3] = 200;
t[1] = 3.5;
p[5] = 225;
t[2] = 1;
AxisZ p[2] = 012.5;
t[0] = 1;
p[5] = 100;
t[1] = 3.5;
p[8] = 112.5;
t[2] = 1;
📜 Sample Code
Basic Streaming PT Motion
  • C#
    int points = 3; // Specify the total number of streamed points.
    int emptyCount = 2; // E-stop generated if there are this number or fewer frames loaded. (Typically for PT motion there are two frames per PT point)
    double[] positions = { 1.0, 0.5, 0.75 }; // Specify the positions that you want to reach. (it can be n number)
    double[] times = { 0.2, 0.3, 0.1 }; // Specify the times in which you want to reach each position. (velocity and acceleration is calculated by the RMP)
    axis.MovePT(RSIMotionType.RSIMotionTypePT, // Specify the type of PT Motion that you want to perform. (RSIMotionType.RSIMotionTypePT, RSIMotionType.RSIMotionTypeBSPLINE, RSIMotionType.RSIMotionTypeBSPLINE2)
    positions, // Specify the positions that you want to reach. (it can be n number)
    times, // Specify the times in which you want to reach each position. (velocity and acceleration is calculated by the RMP)
    points, // Specify the total number of streamed points.
    emptyCount, // E-stop generated if there are this number or fewer frames loaded. (Typically for PT motion there are two frames per PT point)
    false, // Specify whether points are kept, or are not kept.
    true); // Specify if this is the last MovePT. (If True, this is the final point. If False, more points expected.)
    axis.MotionDoneWait(); // Wait for motion to be completed.
Stopping Streaming PT Motion
This code demonstrates that different actions that you can take after stopping a PT Streaming motion.
  • C#
    const int points = 3; // Specify how many points per streaming motion method call.
    const int emptyCount = 2; // E-stop generated if there aren't at least this many points loaded.
    double[] first = { 0.1, 0.2, 0.3 }; // specify the array with position(s) that will go in the first MovePT call.
    double[] second = { 0.4, 0.5, 0.6 }; // specify the array with position(s) that will go in the second MovePT call
    double[] third = { 0.7, 0.8, 0.9 }; // specify the array with position(s) that will go in the third MovePT call
    double[] time1 = { 0.3, 0.3, 0.3 }; // specify the array with time(s) that will go in the first MovePT call.
    double[] time2 = { 0.2, 0.2, 0.2 }; // specify the array with time(s) that will go in the second MovePT call.
    double[] time3 = { 0.25, 0.25, 0.25 }; // specify the array with time(s) that will go in the third MovePT call.
    axis.MovePT(RSIMotionType.RSIMotionTypePT, first, time1, points, emptyCount, false, false); // Start motion and stream a point.
    axis.MovePT(RSIMotionType.RSIMotionTypePT, second, time2, points, emptyCount, false, false); // Append a point.
    // After you Stop() a streaming motion, you can do 2 things.
    // 1. You can either RESUME motion and continue to append.
    // 2. Or you can DISCARD the points before the stop and start new motion.
    axis.Stop(); // Calling Stop() after streaming motion will put you in an STOPPED state.
    //axis.EStop(); // Calling EStop() after streaming motion will put you in an ERROR state.
    // Therefore, you must ClearFaults() before taking any action.
    //axis.Abort(); // Calling Abort() after streaming motion will put you in an ERROR state and trigger an AmpEnable(false).
    // Therefore, you must call AmpEnable(true) before taking action.
    axis.MotionDoneWait(); // Wait for axis to come to a stop.
    axis.Resume(); // Resume() is the key here.
    // If you include Resume() you will append all next streaming points to the old ones.
    // If you do not include Resume() you will discard all previous points and start with new motion with the new points.
    axis.MovePT(RSIMotionType.RSIMotionTypePT, third, time3, points, emptyCount, false, true); // Depending on whether you include Resume() or not this point will be appended or will be starting motion.
