Learn how to use Touch Probe with Panasonic Drives in C#.
- Warning
In this page:
📜 Touch Probe: Capture Index Pulse
Learn how to capture position on each Z-phase (index pulse) during motion using the PDO method. This example configures Touch Probe 1 for continuous capture, triggering on the Z-phase positive edge. Useful for Capture/Probe 📖 applications requiring periodic position capture during motion.
const int TOUCH_PROBE_OUTPUT_INDEX = 3;
const int TOUCH_PROBE_STATUS_INDEX = 6;
const int TOUCH_PROBE_VALUE_INDEX = 7;
const ulong TOUCH_PROBE_ON_EACH_Z_PHASE_COMMAND = 0x17;
ulong currentStatus = controller.NetworkInputValueGet(TOUCH_PROBE_STATUS_INDEX);
Console.WriteLine($"Touch Probe Status: 0x{currentStatus:X}");
ulong lastZPhasePosition = controller.NetworkInputValueGet(TOUCH_PROBE_VALUE_INDEX);
Console.WriteLine($"Last Z-Phase Position: {lastZPhasePosition}");
Source: touch-probe.cs
📜 Touch Probe: Capture Position on Signal
Learn how to capture position on the falling edge of an external input (SI6/EXT2) using the SDO method. This example configures Touch Probe 2 for first-event capture on the falling edge of external input. Ideal for Capture/Probe 📖 applications with discrete trigger events.
const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX = 0x60BD;
const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX = 0x0;
const int TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE = 0x4;
const ulong TOUCH_PROBE_2_ON_FIRST_FALLING_EXT2_COMMAND = 0x2100;
controller.NetworkOutputValueSet(TOUCH_PROBE_OUTPUT_INDEX, TOUCH_PROBE_2_ON_FIRST_FALLING_EXT2_COMMAND);
Console.WriteLine($"Touch Probe 2 Status: 0x{currentStatus:X}");
TOUCH_PROBE_2_FALLING_EDGE_VALUE_INDEX,
TOUCH_PROBE_2_FALLING_EDGE_VALUE_SUB_INDEX,
TOUCH_PROBE_2_FALLING_EDGE_VALUE_SIZE);
Console.WriteLine($"Falling Edge EXT2 Position: {fallingEdgeExt2}");
