Log.cs
Attention
See the following Concept pages for a detailed explanation of this sample: Error Logging.
using NUnit.Framework;
using System;
[TestFixture]
[Category("Software")]
class Log : SampleAppTestBase
[Test]
public void ErrorLog()
// Turn off exceptions. Exceptions will be logged as RsiError objects.
axis.ThrowExceptions(false);
// Do something that will cause an error (zero acceleration).
axis.MoveVelocity(0.0, 0.0);
while (axis.ErrorLogCountGet() > 0)
RsiError error = axis.ErrorLogGet();
Console.WriteLine(error.Message);
int32_t ErrorLogCountGet()
