🔹 RPCs
rpc Network(NetworkRequest) returns (NetworkResponse) {};
🔹 Request
message NetworkRequest {
optional NetworkConfig config = 2;
optional NetworkAction action = 3;
🔹 Response
message NetworkResponse {
optional NetworkInfo info = 4;
optional NetworkStatus status = 5;
🔹 Config
🔹 Action
message NetworkAction {
optional Shutdown shutdown = 1;
optional Discover discover = 2;
optional Start start = 3;
optional DiscoverAndStart discover_and_start = 4;
optional TimingMetricsEnable timing_metrics_enable = 5;
optional TimingMetricsDisable timing_metrics_disable = 6;
optional TimingMetricsClear timing_metrics_clear = 7;
repeated OutputOverride output_override = 8;
optional EniGenerate eni_generate = 9;
message Shutdown { }
message Discover {
optional uint32 timeout_milliseconds = 3;
message Start {
optional uint32 timeout_milliseconds = 2;
message DiscoverAndStart {
message TimingMetricsEnable {
optional uint32 low_threshold = 1;
optional uint32 high_threshold = 2;
message TimingMetricsDisable {}
message TimingMetricsClear {}
message OutputOverride {
int32 index = 1;
optional bool override = 2;
optional FirmwareValue override_value = 3;
message EniGenerate {
optional string output = 2;
🔹 Info
message NetworkInfo {
int32 pdo_input_count = 4;
int32 pdo_output_count = 5;
repeated PdoInputInfo pdo_inputs = 6;
repeated PdoOutputInfo pdo_outputs = 7;
message PdoInputInfo {
string name = 1;
AddressInfo address_info = 2;
int32 bit_size = 3;
int32 bit_offset = 4;
string data_type_name = 5;
message PdoOutputInfo {
string name = 1;
AddressInfo sent_value_address = 2;
AddressInfo override_value_address = 3;
AddressInfo firmware_value_address = 4;
int32 bit_size = 5;
int32 bit_offset = 6;
string data_type_name = 7;
🔹 Status
message NetworkStatus {
int32 node_count = 2;
int32 counter = 3;
bool synchronized = 4;
string log_message = 6;
TimingMetricsStatus timing_metrics = 7;
repeated PdoInputStatus pdo_inputs = 8;
repeated PdoOutputStatus pdo_outputs = 9;
uint32 al_status = 10;
uint32 missed_cyclic_frame_count = 11;
uint32 cyclic_frame_period_us = 12;
int32 synchronization_error_ns = 13;
uint32 active_node_count = 14;
uint64 eoe_host_to_node_frame_count = 16;
uint64 eoe_node_to_host_frame_count = 17;
message TimingMetricsStatus {
uint32 delta = 1;
uint32 min_recorded = 2;
uint32 max_recorded = 3;
uint32 low_count = 4;
uint32 high_count = 5;
bool enabled = 6;
message PdoInputStatus {
int32 index = 1;
FirmwareValue value = 2;
message PdoOutputStatus {
int32 index = 1;
FirmwareValue sent_value = 2;
bool override_enabled = 3;
FirmwareValue override_value = 4;
FirmwareValue firmware_value = 5;
