Learn to setup your RapidCode program using our Python wrapper for the RapidCode API. More...
Topics | |
| 🚀 Get started | |
| Learn RapidCode Python with these sample applications. | |
| ⚙️ Helpers | |
| Helper Functions for checking logged creation errors, starting the network, etc. | |
| Axis: Basic Motion | |
| Basics for getting up and running with Axis motion in RapidCode for Python. | |
| Controller: Create | |
| Create a controller in Python. | |
| IO: Input & Output | |
| Learn how to work with Input/Output operations in Python. | |
| NetworkNode: Error Counts | |
| Learn how to read and display RX error diagnostic counters from all network nodes in an EtherCAT network. The application creates a MotionController object, checks for errors, and if the network is operational, it reads RX error counters from each node and displays them in a formatted table. | |
| Network: Status | |
| Learn how to read and display network and node status diagnostics from an EtherCAT network. The application creates a MotionController object, checks for errors, and displays overall network status along with per-node AL Status, status codes, and CoE emergency messages, including each node's service-channel request counts. | |
| Recorder: Network Status | |
| Learn how to record every EtherCAT network and node status value continuously, so that when a network fails unexpectedly the final records show what happened. The application spreads the NetworkStatus and per-node status addresses over as many Recorders as needed, keeps recording until the network leaves OPERATIONAL (or a key is pressed), then prints a change log and the newest records, and writes the last seconds of every value to a CSV file and the network firmware log to a text file. | |
