Learn how to work with Input/Output operations in Python.
- Warning
In this page:
📜 IO: IOPoint Objects
Learn how to use IOPoint 📖 objects to read and write network data. Shows how to create IOPoint objects for digital outputs and use them to control IO.
""" This sample demonstrates how to use IOPoint objects to read and write network data.
Requires an EtherCAT network with nodes that have digital outputs.
import sys
from _imports import RapidCode, helpers, constants
print("⬤ IO: IOPoint Objects")
exit_code = 0
creation_params: RapidCode.CreationParameters = helpers.get_creation_parameters()
controller: RapidCode.MotionController = RapidCode.MotionController.Create(creation_params)
try:
helpers.check_errors(controller)
NODE_INDEX = 0
OUTPUT_INDEX = 0
userBufferAddress = controller.AddressGet(RapidCode.RSIControllerAddressType_RSIControllerAddressTypeUSER_BUFFER, 0)
output0 = RapidCode.IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX)
output0.Set(False)
print(f"Output {OUTPUT_INDEX} set to: False")
controller.SampleWait(1)
output_value = output0.Get()
print(f"Output {OUTPUT_INDEX} value: {output_value}")
output0.Set(True)
print(f"Output {OUTPUT_INDEX} set to: True")
exit_code = constants.EXIT_SUCCESS
except Exception as e:
print(f"❌ Error: {e}")
exit_code = constants.EXIT_FAILURE
finally:
controller.Delete()
sys.exit(exit_code)
