Axis: Basic Motion
Basics for getting up and running with Axis motion in RapidCode for Python.
In this page:
📜 Axis Basic Motion
Learn how to command basic Axis motion in Python.
""" Sample application that demonstrates basic Axis motion.
import sys
from _imports import RapidCode, helpers, time, config, constants
print("⬤ Axis Basic Motion")
exit_code = 0
# Motion Constants
DISTANCE = 2 # distance to move (in user units)
VELOCITY = 10 # velocity (in user units per second)
ACCELERATION = 5 # acceleration (in user units per second squared)
DECELERATION = 3 # deceleration (in user units per second squared)
JERK_PERCENTAGE = 50 # jerk percentage (0-100%)
# Axis Constants
AXIS_INDEX = 0
def print_status(axis: RapidCode.Axis):
print(f"State: {helpers.enum_to_name(axis.StateGet(), 'RSIState')}, Position: {axis.CommandPositionGet():.5f}, Velocity: {axis.CommandVelocityGet():.5f}, Acceleration: {axis.CommandAccelGet():.5f}")
# get/create the motion controller
creation_params: RapidCode.CreationParameters = helpers.get_creation_parameters()
controller: RapidCode.MotionController = RapidCode.MotionController.Create(creation_params)
try:
helpers.check_errors(controller)
# type hints enable IDE autocomplete for RapidCode objects
print(f"This object is a {type(controller)}")
# Prepare the controller as defined in _config.py depending on the configuration
config.setup_controller(controller, numAxes=AXIS_INDEX + 1)
# get axis
axis: RapidCode.Axis = controller.AxisGet(AXIS_INDEX)
helpers.check_errors(axis)
# ready axis for motion
axis.ClearFaults()
enable_ms = axis.AmpEnableSet(True, 750)
print(f'Amplifier took {enable_ms}ms to enable')
helpers.verify_idle_state(axis)
print_status(axis)
# execute a relative move (distance, velocity, accel, decel, jerk%)
axis.MoveRelative(DISTANCE, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE)
# monitor motion
while not axis.MotionDoneGet():
print_status(axis)
time.sleep(0.1)
print_status(axis)
# clean up
exit_code = constants.EXIT_SUCCESS
except Exception as e:
print(f"❌ Error: {e}")
exit_code = constants.EXIT_FAILURE
finally:
controller.Delete()
sys.exit(exit_code)
