strong |
Reported as the InitializationState field of RapidCodeNetworkNode::StatusGet. The network firmware is the only writer: it advances a node to DISCOVERED when the node is found on the wire and to CONFIGURED once the network configuration parse has populated that node's I/O counts and index tables. Clearing the topology (any discovery or probe pass) returns every node to UNINITIALIZED.
The user label methods use this state: RapidCodeNetworkNode::UserLabelSet requires at least DISCOVERED, and the per I/O point label methods require CONFIGURED because the I/O counts they validate against are not known any earlier.
Definition at line 645 of file rsienums.h.
