| void MoveSCurve | ( | const double *const | position, |
| const double *const | vel, | ||
| const double *const | accel, | ||
| const double *const | decel, | ||
| const double *const | jerkPct ) |
| *position | Array of target positions (in UserUnits for each Axis). |
| *vel | Array of velocities (UserUnits/second). |
| *accel | Array of average accelerations (UserUnits/second/second). (peak up to 2× accel when jerkPercent = 100, see below) |
| *decel | Array of average decelerations (UserUnits). (peak up to 2× decel when jerkPercent = 100, see below) |
| *jerkPct | Array of jerk percents, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 |
