10.6.0
PathRatioSet()
void PathRatioSet
const double *const
ratio
PathRatioSet sets the scale factor ratios for each axis.
ratio
An array of the scale values (1.0 is default).
double
Xunits = MOTOR_RES_16 * REVS_PER_INCH_X;
double
Yunits = MOTOR_RES_16 * REVS_PER_INCH_Y;
double
[] XYRatio =
new
double
[2] { Xunits, Yunits };
multiAxisXY.PathRatioSet(XYRatio);
Use with Path Motion for axes with different encoder resolutions or gearhead ratios. Do Not use UserUnits with PathMotion. Starting in version 4.0.2, this method should be called before PathListStart (but still works if called after).
PathListStart
MultiAxis
1.10.0
