8#include "SampleAppsHelper.h"
   11#include "SampleApps.h"
   15constexpr int MAX_NUM_ARGS = 256;
   23static std::map<std::string, std::shared_ptr<SampleApp>> SampleAppNamesMap =
   25  {
"hardware-limits", std::make_shared<HardwareLimits>()},
   26  {
"memory", std::make_shared<Memory>()},
   27  {
"motion-hold-released-by-software-address", std::make_shared<MotionHoldReleasedBySoftwareAddress>()},
   28  {
"multiaxis-motion", std::make_shared<MultiaxisMotion>()},
   29  {
"path-motion", std::make_shared<PathMotion>()},
   30  {
"pvt-motion-multiaxis", std::make_shared<PVTmotionMultiAxis>()},
   31  {
"single-axis-sync-outputs", std::make_shared<SingleAxisSyncOutputs>()},
   32  {
"sync-output-with-motion", std::make_shared<SyncOutputWithMotion>()},
   33  {
"update-buffer-points", std::make_shared<UpdateBufferPoints>()},
   34  {
"user-limit-digital-input-action", std::make_shared<UserLimitDigialInputAction>()}
   38static void ListSampleApps()
   40  std::cout << std::endl <<
"Available Sample Apps:" << std::endl;
   43  std::shared_ptr<SampleApp> sampleApp;
   44  for (
auto const& sampleAppName : SampleAppNamesMap)
   46    std::cout <<
" - " << sampleAppName.first << std::endl;
   51static void PrintHardwareHelp()
   53  std::cout << std::endl <<
"To run a SampleApp with hardware you must complete the following steps:" << std::endl;
   54  std::cout <<
"  1.  In the source file for the SampleApp, set the axis configuration parameters." << std::endl;
   55  std::cout <<
"  2.  Still in the source file, set the 'USE_HARDWARE' flag to true in the class's run method." << std::endl;
   56  std::cout <<
"  3.  Rebuild this project." << std::endl;
   57  std::cout <<
"  4.  Ensure that you have taken all proper safety precautions appropriate to your particular hardware setup." << std::endl;
   58  std::cout <<
"  5.  Relaunch 'SampleAppsCPP.exe' and run the SampleApp to observe the results." << std::endl;
   62static void PrintHelp()
   64  std::cout << std::endl <<
"Enter the name of a Sample App to run it." << std::endl;
   65  std::cout <<
" - Running on hardware requires additional configuration. Type 'hardware' for more information." << std::endl;
   66  std::cout << std::endl <<
"You may also use 'runall' to run all supported Sample Apps." << std::endl;
   67  std::cout << std::endl <<
"Type 'l' or 'list' to list the available Sample Apps." << std::endl;
   70static void PrintWelcomeMessage()
   72  std::cout <<
"Welcome to the RapidCode C++ Sample Apps!" << std::endl << std::endl;
   73  std::cout <<
"This program allows you to run the sample apps that are included with the RapidCode API." << std::endl;
   74  std::cout << std::endl <<
"WARNING: The sample apps are meant to be used as a reference and may not contain all of the logic and safety features that your application requires." << std::endl;
   75  std::cout <<
"Additionally, in order to mitigate unexpected behavior, running a sample app will reset your RMP controller, clearing any previous configuration." << std::endl;
   76  std::cout << std::endl <<
"It is recommended that you do not have any hardware connected when running the sample apps for the first time." << std::endl;
   77  std::cout <<
"Before you attempt to run a sample app with hardware, please ensure that you have completed the necessary configuration steps and reviewed the source files." << std::endl;
   78  std::cout <<
"Type 'hardware' for more information." << std::endl;
   83static std::shared_ptr<SampleApp> GetSampleApp(std::string sampleAppName)
   86  std::transform(sampleAppName.begin(), sampleAppName.end(), sampleAppName.begin(),
   87    [](
unsigned char c) { return std::tolower(c); });
   90  if (SampleAppNamesMap.find(sampleAppName) == SampleAppNamesMap.end())
   92    throw std::invalid_argument(
"Error: Invalid Sample App name.");
   96  return SampleAppNamesMap.at(sampleAppName);
  100static int RunSampleApp(std::string sampleAppName)
  106  std::shared_ptr<SampleApp> sampleApp;
  109    sampleApp = GetSampleApp(sampleAppName);
  111  catch (std::invalid_argument& e)
  113    std::cout << std::endl << e.what() << std::endl;
  119  std::cout << std::endl <<
"--------------------------------------------------" << std::endl;
  120  std::cout <<
"Running " << sampleAppName <<
"..." << std::endl;
  121  std::cout <<
"--------------------------------------------------" << std::endl << std::endl;
  124    appExitCode = sampleApp->Run();
  126  catch (std::exception& e)
  128    std::cout << std::endl <<
"Error: " << e.what() << std::endl;
  132  std::cout << std::endl <<
  135  if (appExitCode == 0)
  137    std::cout <<
"Sample App " << sampleAppName <<
" completed successfully." << std::endl;
  141    std::cout <<
" completed with errors." << std::endl;
  144  std::cout <<
  152  int runallExitCode = 0;
  154  std::vector<std::string> failedSampleApps;
  155  for (
  157    appExitCode = RunSampleApp(sampleAppName.first);
  160    if (appExitCode != 0)
  162      failedSampleApps.push_back(sampleAppName.first);
  166    if (appExitCode < runallExitCode)
  168      runallExitCode = appExitCode;
  173  if (failedSampleApps.size() > 0)
  175    std::cout << std::endl <<
"The following Sample Apps failed:" << std::endl;
  176    for (
auto const& sampleAppName : failedSampleApps)
  178      std::cout <<
" - " << sampleAppName << std::endl;
  182  return runallExitCode;
  186static std::vector<std::string> GetInput()
  189  std::cout << std::endl <<
"Enter a Sample App name or 'runall'. Type 'h' or 'help' for more info. Type 'q' or 'quit' to end program." << std::endl;
  190  std::cout << std::endl <<
  191  std::getline(std::cin, input);
  193  std::istringstream streamInput(input);
  195  std::vector<std::string> args;
  196  while (std::getline(streamInput, token,
  198    args.push_back(token);
  204static int ProcessInput(std::vector<std::string> args)
  207  if (args.size() < 1 ||
  216  if (args[0] ==
"hardware")
  223  if (args[0] ==
"l" || args[0] ==
"list")
  230  if (args[0] ==
"q" || args[0] ==
"quit")
  237  if (args[0] ==
"runall")
  243  return RunSampleApp(args[0]);
  247std::vector<std::string> ParseArgs(
int argc,
char* argv[])
  249  std::vector<std::string> args;
  251  for (
int i = 1; i < argc; i++)
  255    if (arg ==
"--no-input")
  268int main(
int argc,
char* argv[])
  271  if (argc > MAX_NUM_ARGS)
  273    std::cout <<
"Error: Too many arguments." << std::endl;
  278  std::vector<std::string> args;
  281    args = ParseArgs(argc, argv);
  282    exitCode = ProcessInput(args);
  292  PrintWelcomeMessage();
  298    exitCode = ProcessInput(args);
