License
Activate and download your RMP License.
- RMP licenses are hardware-locked to a USB dongle.
- Please make sure it is connected to the PC before continuing with this guide and/or activating your RMP license.
Precondition
This guide assumes you have completed previous guides to get the RMP running.
1️⃣ Serial Number Retrieval
The RMP license serial number can be retrieved in different ways, follow one method:
  • RapidSetupX 🖥️
    Note: this is possible starting RapidSetupX version 10.6.5.
    Retrieve your Serial Number
    1. (Windows Only) Follow the steps under Starting a rapidserver Instance on the rapidserver page before proceeding.
    2. Open the RapidSetupX tool.
    3. In RapidSetupX, on the "Servers" page, connect to your rapidserver.
      Which rapidserver should I connect to?
    4. Navigate to the "Controller" page.
    5. Click "Create" controller. This will fail to create, but it will populate the Serial Number card.
    6. Copy your Serial Number:
  • RapidSetup 🖥️
    1. Open the RapidSetup tool from your desktop shortcut or C:\RSI\x.x.x
    2. Click copy button so the serial number (decimal value) is in your clipboard.
  • INtime Card
    1. Get a Hex-SerialNumber from the card that was shipped with your pc (1A2B3 in this case).
    2. Convert Hex-SerialNumber(1A2B3) to Decimal-SerialNumber(107187).
      • Open a calculator app and switched it to programmer mode.
      • Type in Hex-SerialNumber
    3. Decimal-SerialNumber(107187) is the correct value to be downloaded from License Server.
    4. Keep that number, you will need it later in Step 4. (to Enter Customer Serial#).
2️⃣ License Download
Download the RMP rsi.lic from our customer portal.
  1. Follow the link to the customer portal and click any of the two Log in buttons.
  2. Login with the account that RSI has authorized for your company.
  3. Navigate to the license page.
  4. Once you are in the new Licenses page, you should see your available POs as so:
    This customer only contains 2 Purchase Orders in total with custom info.
  5. Expand the desired PO you want to download a license for:
    This particular PO only contains 1 PO Group. All 5 licenses in this PO
   Group will be identical.
  6. To download a license, click on the download icon.
  7. A pop up should appear, enter your RMP serial number, then click the Download button:
    Feel free to enter some more extra info or a the Machine S/N where the
   license will run (not needed).
  8. The license will download with following name structure: RMP_SERIAL_NUMBER.lic
  9. Rename the downloaded license to rsi.lic
  10. Move your license file inside your RMP/RSI folder.
    • Windows: C:/RSI/X.X.X
    • Linux /rsi
