User Limits
Configure and observe User Limits.
User Limits Screen User Limits Screen
User Limits can be created via RapidCode (API) calls or using RapidSetup (Tool) by navigating to the controller screen and setting the desired User Limit Count.
🔹 List
Existing User Limits.
  • **#** shows the user limit index in the motion controller.
  • STATE shows if the specific User Limit is triggered (HIGH) or not triggered (LOW).
  • ENABLED shows if the specific User Limit is enabled and processed in real-time by the RMP or not . (if not enabled then user limit will never trigger)
🔹 Configuration
Setup your User Limit.
  • Single-Shot If true, the User Limit will be disabled after it triggers one time. The default behavior is false which means it will re-trigger whenever conditions are met.
  • Enable Output Returns true if the user limit output is enabled.
  • Trigger Type Single, And, OR logic will be used
  • Duration The time delay (in seconds) before the action is executed after the User Limit has been triggered. The resolution of the duration is sample periods (default is 1ms).
  • Action Axis Number Select the axis that the action (defined above) will occur on.
  • Action The action to be taken. Options include: Axis ESTOP, Axis STOP, Axis ABORT, Digital Output State Change, Proportional Gain Change, Monitor Different Variables
🔹 Condition
Define your condition(s) that will trigger the User Limit.
🔹 Output
There are several different versions of Outputs which can be used with User Limits. The following are the sets of parameters that are used for supported variations.
  • Input Firmware Address - When 'Input Firmware Address' and 'Firmware Address' have entries, the UserLimit will copy the value from the Input -> Firmware Address.
  • Double Copy - When 'Firmware Address' has an entry and the Data Type is Double, the 'Limit Value' will be copied into the 'Firmware Address' when the Limit Triggers.
  • Mask AND/OR - When 'Firmware Address' has an entry and the Data Type is Int32 or Mask32, the 'AND Mask' and 'OR Mask' will be applied to the 'Firmware Address'.
🔹 Set & Enable
Turn your User Limit ON or OFF
