Electronic Gearing
Table of Contents
Gearing links two or more axes such that the position of the “slave” axis is a function of the position of the “master” axis.
RapidSetup - Electronic Gearing
🔹 Gearing Parameters
Learn more about Electronic Gearing in our concept page.
  • Gearing State displays whether you have successfully geared 2 axes or not.
  • Master Axis Number represent which axis to be setup as the master.
  • Gearing Source allows you to select which source the slave will be geared to.
  • Numerator (A) & Denominator (B) define the gearing ratio between the master and slave.
  • Enable & Disable Buttons enable/disable gearing in RapidSetup.
