Quick and easy way to issue commands to the AKD drive directly.
Functional for Kollmorgen AKD drives only.
- The terminal mode provides a quick and easy way to issue commands to the drive directly.
- Typically used by "power users" who are familiar with the command set, the terminal mode can help in setup, troubleshooting, and other diagnostic actions.
- When using the terminal mode, RapidSetup shows the parameter and command set in a popup view and uses an autocomplete tool to help you select the proper parameter or command.
- Click the right arrow in the command entry area to open a popup menu to see all available commands.
