Add NodeB to your INtime setup.
1.1.1 Open the Intime Configuration tool and select Node Management.
.png)
1.1.2 Click the "New Node**"** button and:
.png)
1.2.1 Select "Kernel" tab and:
.png)
1.3.1 Select "Auto Load" tab and:
.png)
1.4.1 Select "Network" tab and:
.png)
.png)
2.1.1 Navigate to _"Control Panel\Network" and "Internet\Network Connections"._ (See below)
.png)
2.1.2 Right-click on your newly created INtime Ethernet Driver and select "Properties".
.png)
2.1.3 Select the "Sharing" tab and:
.png)
Command Prompt Steps
STEP 1 - Create a new DWORD registry subkey
3.2.3 Enter the command ā
STEP 2 - Change the Service Internet Connection Sharing (ICS) Startup type to Automatic
3.2.2 Enter the command ā sc config SharedAccess start=auto
Manual Steps
3.2.1 Open the "Registry Editor", you can just search for it or hit (WindowKey+R) to open the run prompt and type regedit.
.png)
3.2.2 Navigate to _HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\SharedAccess_
.png)
3.2.3 Create a new DWORD (32-bit) registry subkey with:
.png)
3.2.4 Open "Services", you can just search for it.
.png)
3.2.5 Once open, scroll down to the āiā section and look for Internet Connection Sharing (ICS) and right-click on its "Properties".
.png)
3.2.6 In the Properties menu:
