Learn how to create a MotionController, set an AxisCount and get Axis status in Python.
- Warning
- Precondition
- Python has the library grpcio-tools, which can be installed using the Pip package manager. The command to install looks like pip3 install grpcio-tools. The grpcio-tools package also provides command line utilities to build gRPC code from a proto file. The Python script requires the following imports (some of which are scripts generated by grpcio-tools) at the top:
import grpc
import rapidgrpc_pb2 as rapidgrpc
import rapidgrpc_pb2_grpc as rapidgrpc_stubs
import rapidcode_pb2 as rapidcode
import rapidcode_pb2_grpc as rapidcode_stubs
import rsienums_pb2 as rsienums
The following helper function is used to check each response message for errors:
def do_rpc(rpc, request):
response = rpc(request)
num_errors = len(response.header.errors)
if (num_errors > 0):
raise Exception(f"Last RPC had {num_errors} errors! {response.header.errors}")
return response
Stub Creation
Create a stub to use RMPService's RPCs. grpc.insecure_channel is a class from the Python grpcio-tools package that establishes a connection to the server listening at the specified IP and port.
channel = grpc.insecure_channel(format_address(ip_address, port))
rmp_stub = rapidcode_stubs.RMPServiceStub(channel)
📜 Server Info
Get some information about the server.
server_stub = rapidgrpc_stubs.ServerControlServiceStub(channel)
info_request = rapidgrpc.ServerGetInfoRequest()
info_response = do_rpc(server_stub.GetInfo, info_request)
print(f"Received GetInfoResponse from server...\n"
f"ID: {info_response.id:x}\n"
f"Name: {info_response.name}\n"
f"Version: {info_response.version}")
📜 Create a Motion Controller
Create a motion controller on the server with a specified number of axes.
motioncontroller_request = rapidcode.MotionControllerRequest()
motioncontroller_request.action.create.node_name = RMP_NODE_NAME
motioncontroller_request.config.axis_count = AXIS_COUNT
motioncontroller_response = do_rpc(rmp_stub.MotionController, motioncontroller_request)
📜 Check the status of an Axis
Check the current state within the status message of an Axis.
axis_request = rapidcode.AxisRequest()
axis_request.index = 0
axis_status_response = do_rpc(rmp_stub.Axis, axis_request)
response_state = axis_status_response.status.state
print(f"Axis state: {rsienums.RSIState.Name(response_state)}")
