Quick Start
Learn how to use RapidCodeRemote (gRPC) for remote control of RMP hardware in C#.
In this page:
📜 Client Creation
Learn how to set up the gRPC client to communicate with the RapidServer.
// create grpc channel and clients
var address = $"http://{Constants.RAPIDSERVER_IP}:{Constants.RAPIDSERVER_PORT}";
var channel = GrpcChannel.ForAddress(address); // grpc channel used to communicate with the server
var serverClient = new ServerControlServiceClient(channel); // grpc client for using the ServerControlService
var rmpClient = new RMPServiceClient(channel); // grpc client for using the RMPService
📜 Server Info
Learn how to query server details and verify connection. Shows how to retrieve server name, ID, and version information.
// request and display basic information about the server
void ServerInfoGet(ServerControlServiceClient client)
Console.WriteLine("\n 📜 Server Info");
ServerGetInfoRequest infoRequest = new ServerGetInfoRequest();
ServerGetInfoResponse infoResponse = client.GetInfo(infoRequest);
CheckErrors(infoResponse.Header);
Console.WriteLine($"Connected to server named '{infoResponse.Name}' with ID: {infoResponse.Id:X}");
Console.WriteLine($"Server version: {infoResponse.Version}");
📜 Controller Creation
Learn how to create a remote MotionController on the server. Shows how to initialize the motion control system via gRPC.
// create the MotionController on the server
void ControllerCreate(RMPServiceClient client)
Console.WriteLine("\n 📜 Controller Create");
MotionControllerResponse motionControllerResponse = client.MotionController(new MotionControllerRequest
Action = new MotionControllerAction { Create = new MotionControllerCreationParameters() }
CheckErrors(motionControllerResponse.Header);
Console.WriteLine("Motion Controller created successfully");
📜 Controller Shutdown
Learn how to properly shutdown the remote motion controller. Shows how to cleanly terminate the motion control system.
// shutdown the motion controller
void ControllerShutdown(RMPServiceClient client)
Console.WriteLine("\n 📜 Controller Shutdown");
Action = new MotionControllerAction { Shutdown = new MotionControllerAction.Types.Shutdown() }
Console.WriteLine("Motion Controller shut down successfully");
📜 Network Start
Learn how to start the EtherCAT network.
// start the EtherCAT network
void NetworkStart(bool discoverBeforeStart = false)
Console.WriteLine("\n 📜 Network Start");
var action = new NetworkAction();
if (discoverBeforeStart)
action.DiscoverAndStart = new NetworkAction.Types.DiscoverAndStart();
action.Start = new NetworkAction.Types.Start();
NetworkResponse networkResponse = rmpClient.Network(new NetworkRequest
Action = action
CheckErrors(networkResponse.Header);
📜 Axis Count
Learn how to set the axis count for phantom axes. Shows how to configure the number of axes remotely.
// set the axis count so we have phantom axes to work with
void AxisCountSet(RMPServiceClient client)
Console.WriteLine("\n 📜 Axis Count");
Config = new MotionControllerConfig { AxisCount = Constants.AXIS_COUNT }
Console.WriteLine($"Axis count set to: {motionControllerResponse.Config.AxisCount}");
📜 Axis Status
Learn how to check axis state and status remotely. Shows how to retrieve current axis information via gRPC.
// check the state of the axis at index 0
void AxisStatusGet(RMPServiceClient client)
Console.WriteLine("\n 📜 Axis Status");
AxisResponse axisResponse = client.Axis(new AxisRequest { Index = Constants.AXIS_0_INDEX });
CheckErrors(axisResponse.Header);
Console.WriteLine($"Axis {Constants.AXIS_0_INDEX} state: {axisResponse.Status.State}");
📜 Axis Motion: Point-to-Point
Learn how to execute simple position moves remotely. Shows how to configure axis, clear faults, and command point-to-point moves.
// demonstrate a simple point-to-point move
void AxisMotionPointToPoint(RMPServiceClient client)
Console.WriteLine("\n 📜 Axis Motion: Point-to-Point");
// configure the axis for phantom use
Config = new AxisConfig
ErrorLimit = new AxisConfig.Types.ErrorLimit { Action = RSIAction.None } // ignore position errors for phantom axis
// clear any faults and set initial position
Action = new AxisAction
Abort = new AxisAction.Types.Abort(),
ClearFaults = new AxisAction.Types.ClearFaults(),
PositionSet = new AxisAction.Types.PositionSet { Position = 0 }
// command a point-to-point move from position 0 to position 10
var moveAction = new AxisAction
Move = new AxisAction.Types.Move
PointToPoint = new AxisMovePointToPoint
Acceleration = 100,
Deceleration = 100,
Velocity = 10,
Position = 10,
JerkPercent = 50
axisResponse = client.Axis(new AxisRequest { Index = Constants.AXIS_0_INDEX, Action = moveAction });
Console.WriteLine($"Commanded move to position 10");
Console.WriteLine("Waiting for axis to stop moving...");
while (true)
if (axisResponse.Status.State != RSIState.Moving)
System.Threading.Thread.Sleep(100);
// check final position
Console.WriteLine($"Final command position: {axisResponse.Status.Position.Command}");
📜 Axis Motion: Streaming
Learn how to continuously stream motion points for complex trajectories. Shows how to send batches of streaming points and manage motion execution.
// demonstrate streaming motion with continuously added points
void AxisMotionStreaming(RMPServiceClient client)
Console.WriteLine("\n 📜 Axis Motion: Streaming");
// wait for any previous motion to complete
while (true)
// clear faults and set initial position
// get initial motion id
int originalMotionId = (int)axisResponse.Status.MotionId;
// create first batch of streaming points (sine wave pattern)
var streamingMove = new MoveStreaming();
int numPoints = 100;
double amplitude = 1.0;
for (int i = 0; i < numPoints; i++)
double position = Math.Sin(i / (double)numPoints * 2 * Math.PI) * amplitude;
streamingMove.Positions.Add(position);
streamingMove.Times.Add(1.0 / numPoints);
streamingMove.EmptyCount = 50;
streamingMove.Retain = false;
streamingMove.Final = false;
// send first streaming move
Move = new AxisAction.Types.Move { Streaming = streamingMove }
Console.WriteLine("Sent first streaming move batch");
// add additional batches while motion executes
int previousMotionId = (int)axisResponse.Status.MotionId - 1;
for (int batch = 2; batch <= 5; batch++)
// wait for previous batch to start executing
while (true)
if (axisResponse.Status.MotionIdExecuting >= previousMotionId)
System.Threading.Thread.Sleep(10);
// create next batch with increasing amplitude
amplitude = batch;
streamingMove.Final = (batch == 5); // mark last batch as final
Console.WriteLine($"Sent streaming batch {batch} (amplitude={amplitude}, final={streamingMove.Final})");
Console.WriteLine("Waiting for streaming motion to complete...");
while (true)
// get motion status
Console.WriteLine($"Streaming motion complete. Final state: {axisResponse.Status.State}");
📜 Error Handling
Learn how to check RPC responses for errors. Shows how to validate server responses and handle error conditions.
// check response header for errors and throw if any exist
void CheckErrors(RSI.RapidServer.ResponseHeader header)
if (header.Errors.Count > 0)
string message = "RPC had errors:\n";
foreach (var error in header.Errors)
message += $" {error.Message}\n";
throw new Exception(message);
