Quick Start
Learn how to create a MotionController, set an AxisCount and get Axis status.
Precondition
A helper function to check each response for errors.
// Check each response header for errors. Stop execution if errors were received.
private static void CheckErrors(ResponseHeader header)
if (header.Errors.Count > 0)
string message = "RPC had errors!\n";
foreach (var error in header.Errors)
message += " " + error.Message + "\n";
Assert.Fail(message);
📜 Client Creation
Create an instance of RMPServiceClient. Channel is a class from the C# gRPC API that establishes a connection to the server listening at the specified IP and port.
channel = new Channel(ipAddress, PORT, ChannelCredentials.Insecure);
rmpClient = new RMPService.RMPServiceClient(channel);
📜 Create a Motion Controller
Create a motion controller on the server.
// First, before doing any other RapidCodeRemote RPCs, create the motion controller on the server
MotionControllerResponse motionControllerResponse = rmpClient.MotionController(new MotionControllerRequest
Action = new MotionControllerAction { Create = new MotionControllerAction.Types.Create() },
CheckErrors(motionControllerResponse.Header);
📜 Set the Axis count
Set the axis count within the motion controller.
// Next, set the axis count so we have axes to work with.
Config = new MotionControllerConfig { AxisCount = Constants.AXIS_COUNT },
Assert.That(motionControllerResponse.Config.AxisCount, Is.EqualTo(Constants.AXIS_COUNT), "Expected returned axis count to be what we set it to!");
📜 Check the status of an Axis
Check the current state within the status message of an Axis.
// Check the state of the axis at index 0
AxisResponse axisResponse = rmpClient.Axis(new AxisRequest { Index = 0 });
CheckErrors(axisResponse.Header);
Assert.That(axisResponse.Status.State, Is.EqualTo(RSI.RapidCodeRemote.RSIState.Idle), "Expected axis state to be IDLE!");
