11.1.1
gcode-feed-rate-set-behavior
Setting the G-code feed rate (either with an
F
word or call to
Gcode::FeedRateSet
) with the argument
f
does the following:
f > 0
: sets the target feed rate to
f
(unless
f
is vanishingly small).
f == 0
: clears the feed rate with no error. Use this to intentionally prevent feed-governed motion.
Otherwise: yields an error to indicate that the argument was rejected and clear the feed rate to prevent malformed motion.
1.15.0
