controller-create.py
See Controller: Create 📜 for a detailed explanation of this sample code.
1""" Sample application that creates an RMP Motion Controller object and prints its information.
2"""
3
4import sys
5from _imports import RapidCode, helpers, constants
6
7exit_code = 0
8
9# METHODS
10def print_topology(controller:RapidCode.MotionController):
11 stringBuilder = []
12 overview = "EtherCAT: {} Nodes, Type: {}, State: {}".format(
13 controller.NetworkNodeCountGet(),
14 helpers.enum_to_name(controller.NetworkTypeGet(), "RSINetworkType"),
15 helpers.enum_to_name(controller.NetworkStateGet(), "RSINetworkState")
16 )
17 stringBuilder.append(overview)
18
19 Nodes = []
20 for i in range(controller.NetworkNodeCountGet()):
21 node = controller.NetworkNodeGet(i)
22 helpers.check_errors(node)
23 if(node.Exists()):
24 Nodes.append(node)
25
26 for node in Nodes:
27 stringBuilder.append("") # for spacing
28 stringBuilder.append("Node[{}] - {} ______________________________________________".format(node.NumberGet(), node.NameGet()))
29 stringBuilder.append(" Vendor: {} ".format(node.VendorNameGet() + "Product: {}".format(node.ProductNameGet())))
30 stringBuilder.append(" VendorID: 0x{:08X} ProductCode: 0x{:08X}".format(node.VendorIdGet(), node.ProductCodeGet()))
31 stringBuilder.append(" HardwareRev: 0x{:08X} SerialNumber: {}".format(node.RevisionGet(), node.SerialNumberGet()))
32 stringBuilder.append(" StationAlias: 0x{:08X} AxisCount: {}".format(node.StationAliasGet(), node.AxisCountGet()))
33 stringBuilder.append(" SegmentCount: {}".format(node.SegmentCountGet()))
34 stringBuilder.append(" DI: {} DO: {} AI: {} AO: {}".format(node.DigitalInCountGet(), node.DigitalOutCountGet(), node.AnalogInCountGet(), node.AnalogOutCountGet()))
35
36 stringBuilder.append("") # spacing
37 pdoInputs = controller.NetworkInputCountGet()
38 stringBuilder.append("NetworkInputs count: {} _________________________________".format(pdoInputs))
39 for i in range(pdoInputs):
40 stringBuilder.append(" [{}] - {} Bits: {}".format(i, controller.NetworkInputNameGet(i).ljust(70), controller.NetworkInputBitSizeGet(i)))
41
42 pdoOutputs = controller.NetworkOutputCountGet()
43 stringBuilder.append("NetworkOutputs count: {} _________________________________".format(pdoOutputs))
44 for i in range(pdoOutputs):
45 stringBuilder.append(" [{}] - {} Bits: {}".format(i, controller.NetworkOutputNameGet(i).ljust(70), controller.NetworkOutputBitSizeGet(i)))
46
47 print("\n".join(stringBuilder))
48
49
50# MAIN
51print("⬤ Controller Create")
52
53creation_params: RapidCode.CreationParameters = helpers.get_creation_parameters()
54controller: RapidCode.MotionController = RapidCode.MotionController.Create(creation_params)
55
56try:
57 helpers.check_errors(controller)
58
59 # type hints enable IDE autocomplete for RapidCode objects
60 print(f"This object is a {type(controller)}")
61
62 # print some controller info
63 print(f"RapidCode Version: {controller.VersionGet()}")
64 print(f"Serial Number: {controller.SerialNumberGet()}")
65 print(f"Axis Count: {controller.AxisCountGet()}")
66
67 # print network topology
68 if controller.NetworkStateGet() == RapidCode.RSINetworkState_RSINetworkStateOPERATIONAL:
69 print_topology(controller)
70
71 exit_code = constants.EXIT_SUCCESS
72except Exception as e:
73 print(f"❌ Error: {e}")
74 exit_code = constants.EXIT_FAILURE
75finally:
76 # clean up
77 controller.Delete()
78
79sys.exit(exit_code)
