For DS402 axes, the RMP firmware will automatically generate an Amp Fault action (default is to Abort) if the AMP_ACTIVE signal does not got high within one second of AmpEnableSet(true). If it fails to enable, the Axis will end in an ERROR state. This value is configurable using RSIAxisAddressType::RSIAxisAddressTypeAMP_ENABLE_AMP_FAULT_TIMEOUT with MotionController::MemoryDoubleGet() and MotionController::MemoryDoubleSet(). The default value is Axis::AmpEnableAmpFaultTimeoutSecondsDefault.
