Upgrading From Rapidcode 8 To 10
RapidCode: Upgrade version (8 to 10)
🔹 General Requirements
Remember to restart your INtime node before trying to running different versions of RMP
🔹 Important Name Changes
lib/dll Name in RapidCode 8 Name in RapidCode 10
C++ RSIQVC RapidCode
.NET x86 (32 bit) RSIQDNET4 RapidCode.NET
.NET x64 (64 bit) RSIQDNET64 RapidCode.Net64
32-bit dll now are located in RSI/10.x.x/x86\ You may want to move them to your root RSI/10.x.x folder.
🔹 Notable API Changes
Action Code in RapidCode 8 Code in RapidCode 10
Restart RTOS RTOS.RTOSGet().INtimeRestart(); RTOS.INtimeRestart();
🔹 Directory Structure Change
x64 files are now located in the root install directory. x86 files can be found in the subfolder of the same name.
🔹 Upgrading your code from 8 to 10
All RapidCode.NET interface files (prefixed with I) have been removed in RapidCode 10. Simply use the RapidCode class name instead.\
Case Matching Find and Replace to remove I prefixed interfaces
🔹 Step by Step Instructions
1. Update your build and debug directories to match the root of your new version of RMP for All Configurations:
Debug:
Debug image
Build:
Build image
2. Update your projects reference
Remove the old RMP 8 dll (RSIQDNET64.NET.dll):\
8dll
Add the new RMP 10 dll (RapidCode64.NET.dll):
10dll
