Template.cpp
17#include "rsi.h" // Import our RapidCode Library.
18#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
19
20using namespace RSI::RapidCode; // Import the RapidCode namespace
21
23void TemplateMain(int argc, char *argv[])
24{
25 const int AXIS_X = (0);
26 const int AXIS_Y = (1);
27 const int IO_NODE = (7);
28
29 Axis *axisX;
30 Axis *axisY;
31 MultiAxis *multiAxisXY;
32 IO *io;
33
34 // Create and initialize RsiController class
37 try
38 {
39 // enable one MotionSupervisor for the MultiAxis
40 controller->MotionCountSet(controller->AxisCountGet() + 1);
41
42 // Get Axis X and Y respectively.
43 axisX = controller->AxisGet(AXIS_X);
45
46 axisY = controller->AxisGet(AXIS_Y);
48
49 // Initialize a MultiAxis, using the last MotionSupervisor.
50 multiAxisXY = controller->MultiAxisGet(controller->MotionCountGet() - 1);
52 multiAxisXY->AxisAdd(axisX);
53 multiAxisXY->AxisAdd(axisY);
54
55 // Initialize an IO.
56 io = controller->IOGet(IO_NODE);
57
58 // Insert your application code here.
59 }
60 catch (RsiError const& err)
61 {
62 printf("\n%s\n", err.text);
63 }
64 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
65 system("pause"); // Allow time to read Console.
66}
67
Definition rsi.h:5526
Definition rsi.h:11433
int32_t AxisCountGet()
int32_t MotionCountGet()
Definition rsi.h:795
void AxisAdd(Axis *axis)
Definition rsi.h:10221
Definition rsi.h:106
